Author Topic: Help with Geometry settings ??????  (Read 2384 times)
Offline gazon69
« on: March 26, 2012, 05:08:46 pm »
Hi guys, i am fitting my walk and bilstein b12 kit with h&r springs at the weekend. The car should be lowered around 30mm. Can anyone tell me what my geometry settings should be for normal road use as i will be taking it for a full set up once all is fitted. Cheers guys.
« Last Edit: March 26, 2012, 05:22:24 pm by gazon69 »
Offline gazon69
Re: Help with Geometry settings ??????
« Reply #1 on: March 29, 2012, 08:26:34 am »
Anyone??????
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ouvqhmbhmv7hbi6jestrfn31nv&/topic,19740.0.html
« Reply #2 on: March 29, 2012, 08:35:58 am »
If you take it to somewhere that knows what they are doing, they will know the settings that you require. If they don't, the chances are they don't know what they are doing.
Offline Jussa
  • Bicester
« Reply #3 on: March 29, 2012, 08:32:51 pm »
 :signLOL: good point Rich!!!
Just make sure you take it to a 4 wheel geometry specialist, anything else won't be good enough!!
Offline heavyd
  • -Receive: 29
« Reply #4 on: March 30, 2012, 01:19:20 am »
http://www.alignmycar.co.uk/CentreLocator
has all the 4 wheel aligment centres on it :happy2:
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #5 on: March 30, 2012, 07:50:59 am »
I always set the front as close to but not over 1deg toed in, 0.5deg toed in is perfect for less HP cars. And the rear is always between -1.0 to -1.5 camber.
Offline gazon69
« Reply #6 on: March 30, 2012, 07:06:46 pm »
Right, here's where it stands. I have been to a 4 wheel alignment center local to me, he has the state of the art machine. I have spoken to the operator and he is telling me that he will only be able to align  my car to the standard settings at normal ride height, but as i am fitting h&r springs then i am assuming that those settings will be useless. Hope you understand this coz i dont,    :confused:
Offline welikeaps
  • -Given: 22
« Reply #7 on: April 02, 2012, 09:53:38 pm »
was told the same thing based on the above information today. I was also told that they can't adjust the front castor either, which seems off so i left and am going to ask elsewhere.
« Last Edit: April 03, 2012, 12:53:40 pm by welikeaps »
Offline gazon69
« Reply #8 on: April 03, 2012, 09:59:17 am »
Car is around the 300 mark so what to you suggest
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #9 on: April 03, 2012, 12:09:54 pm »
Road only: alignment to Volkswagen specs
And try a search if you feel a need to learn more. Your're not the first.
"You get what you pay for."
Offline SteveyD
« Reply #10 on: April 03, 2012, 11:20:57 pm »
Depending on your location try somewhere like http://www.ninemeister.com/ I know a guy who does all the body shop stuff for them.  The owner is very clued up including Motorsport prep & F1.
