Author Topic: Aaaaaargh! There's been a run on V Power!  (Read 7780 times)
Offline ktlstar
Re: Aaaaaargh! There's been a run on V Power!
« Reply #30 on: March 30, 2012, 11:17:37 pm »
Engine catastrophe,
But serious note, Datalogs from my car with 97 and 99ron, the difference was dramatic, timing was being pulled all across the cylinders, where 99ron it reduced it to safe levels.
Would you be on WOT @ 95 ron fuel with  a 99ron map ? Good luck.
The ECU will retard timing to safe levels, its perfectly fine to run a mapped car on 95, but you won't be getting the best performance out of it.
Would you say this is safe then ?
thats with 97 ron.
« Last Edit: March 30, 2012, 11:21:22 pm by ktlstar »
- #1240 ED30 Revo STAGE2+
- Southeast - Vag Com owner
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #31 on: March 30, 2012, 11:24:50 pm »
Erm no!!
You have a lot of sustained timing pull over 5 on cylinder 1&4 for nearly the entire rev range. That's not good!
Offline ktlstar
« Reply #32 on: March 30, 2012, 11:26:19 pm »
^ Exactly. My car is mapped for 99 ron and not 97 ron. Just shows you the timing are being pulled for putting the wrong grade of fuel in.
Happy  :driver:
« Last Edit: March 30, 2012, 11:28:45 pm by ktlstar »
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=vmcq1kghfsvoopk88l63thp2kj&/topic,19740.0.html
« Reply #33 on: March 30, 2012, 11:30:28 pm »
I was referring to someone with a stage 1 (read back the thread) map not a stage 2+ balls out map.
If he has to put in a tank of 95 then its not gonna wreck his engine.
Ive put in 95 before on my stage 1 ed30.. and its still going strong today (i use 99ron 99% of the time)
« Last Edit: March 30, 2012, 11:32:12 pm by richwig83 »
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #34 on: March 30, 2012, 11:32:28 pm »
Fully agree Rich. I was just saying that the log posted wasn't good  :drinking:
« Reply #35 on: March 30, 2012, 11:34:22 pm »
Offline ktlstar
« Reply #36 on: March 30, 2012, 11:35:26 pm »
You highlighted my comment Rich, so i assumed you was referring to my comment i.e stage2+.
I think we need a data log 95 97 99ron for stage1 revo map :)
« Reply #37 on: March 30, 2012, 11:39:22 pm »
CBA... too much faff.  :signLOL:
Offline gulfstream11
« Reply #38 on: March 31, 2012, 12:09:14 am »
I have a 95ron setting on my sps... Never used it,has anybody?
« Reply #39 on: March 31, 2012, 12:14:02 am »
whats the vpower situation in donny Gulf?
« Reply #40 on: March 31, 2012, 12:18:06 am »
Balby road still running,not sure on the york rd station.. If you're going to the PDT day better stoke up..
Offline Kalpsn2000
  • -Receive: 56
« Reply #41 on: March 31, 2012, 12:36:05 am »
Need to fill mine this evening, hope there is some of the good stuff left at either of my 2 local Shells.
Both out of V Power, had to put the 95 ron stuff in.
