Author Topic: To anyone that has upgraded their speakers..  (Read 1996 times)
Offline Alexander
« on: May 10, 2009, 03:51:28 pm »
Did you have to cut holes in the metal skin in the door to fit the mid drivers?
I took my infinity kappa 1.7cs speakers to a fitter to get a quote for fitting and he took the door card off and said he reckons he is going to have to cut into the metal door skin to fit the mid range speakers.
Some people say that cutting this skin can set off the airbag fault light because of the pressure difference which has me worried.
What speakers have other people fitted and did they go in ok?
Alex
2005 Black Audi A3 Sportback TDI-Bose and Full Leather
2005 Black 3Dr GTI-Leather and Upgraded Sound System-Gone
Re: To anyone that has upgraded their speakers..
« Reply #1 on: May 10, 2009, 04:43:27 pm »
I have Hertz "hi-energy" range speakers in the doors - comps up front and coax's in the rear. I didn't fit them myself, but the originals are rivetted in from what I can recall. The Hertz ones went straight in without any issues. :happy2:
Offline Alexander
« Reply #2 on: May 10, 2009, 05:48:31 pm »
Cheers Hurdy. Just looked online and found the following:
Infinity" Kappa 1.7cs" Midrange Driver: Mounting Depth: 47mm
Hertz:" HSK163.3" Midrange mounting depth: 41mm
Hertz: "ESK163L.3" Mid-range Mounting depth: 28mm (orange speakers)
Couldnt see any mention of the hi energy speakers but the Hertz ESK163L.3 have a much smaller mounting depth than the other hertz or my infinitys. Will see if I can get the specs for the high energy speakers.
Are yours orange or black speakers Hurdy?
« Last Edit: May 10, 2009, 05:56:56 pm by Alexander »
« Reply #3 on: May 10, 2009, 08:48:29 pm »
Mine are black. The orange ones are the slightly lower spec ones....but still good. :happy2:
Linky
http://www.hertzincar.co.uk/component.php
« Last Edit: May 10, 2009, 08:50:01 pm by Hurdy »
Offline Alexander
« Reply #4 on: May 11, 2009, 11:54:10 am »
Then your mid drivers should be 6mm shallower than mine. Don't suppose you know how tightly yours fitted in? I'll be very annoyed if its that 6mm causing me grief!
