Author Topic: advice on water pump  (Read 2649 times)
Offline mumf78
« on: April 18, 2012, 08:17:30 pm »
as above im having my cambelt changed next weekend and while its stripped im going to change the water pump. the car is a 2006 golf gt tdi 140. iv heard about the plastic impeller pumps breaking and the other story is the metal impeller shattering and damaging the engine. vw say there supplied pump is plastic. i really dont know which one to go for. your feedback will be greatly appreciated!
Re: advice on water pump
« Reply #1 on: April 18, 2012, 09:03:13 pm »
the metal ones can come away too so i have heard  :scared:
Offline mumf78
« Reply #2 on: April 18, 2012, 09:14:48 pm »
ye thats what i put in the above post. i really dont know for the best. my local parts supplier said all the parts are oem spec and the pump is plastic. not one recall!
« Reply #3 on: April 18, 2012, 09:18:22 pm »
just go for the one thats in stock thats all you can do  :smiley:
Offline 56OctyVRS
  • -Receive: 72
« Reply #4 on: April 18, 2012, 10:01:47 pm »
The pump I removed from my car last year was plastic and the prop showed no sign of cracking and looked as good as new. The pump will have a two year guarantee anyway so I wouldnt worry about it.
Offline omeydz
  • -Receive: 50
« Reply #5 on: April 22, 2012, 12:25:43 pm »
OEM stock is best. If anything happens during the guarantee period, you have that to fall on!
Recently back on the forum! Good to be back
Current Rides
Mazda RX8 231bhp ( very different little rocket lol!)
SOLD
2007 MK5 Golf 1.4 FSI
2007 Golf MK5 GTI DSG
2008 Audi A5 3.0TDI
  • -Given: 380
  • -Receive: 442
« Reply #6 on: April 22, 2012, 12:40:14 pm »
IIRC, I have read on this forum a long time ago that it is strongly advised to change the pump at the same time as a cambelt. The reasons given were fully explained but I don't exactly remember and don't want to unintentionally misinform.
Offline Tamiyoman
  • -Receive: 39
« Reply #7 on: April 22, 2012, 01:26:27 pm »
For the sake of £60 its worth having it changed, my 08 plate ED30 is booked in for Cambelt/Waterpump service on tuesday 24th, for £60 I decided to get it done at same time!
Offline Phil Miller
  • -Given: 86
« Reply #8 on: April 22, 2012, 01:43:26 pm »
Two sides to this coin, first up the plastic impellers dont crack that often, what they do is come loose on the shaft, when cold its a snug fit when the engine warms up it expands slightly and then is free so doesnt move the coolant as it should, metal impellers, now ive NEVER had any problems with these, and always replace water pumps with metal, as the impeller doesnt come free like the plastic
the other side of the coin, if a plastic one comes free it normally just sits there and does nothing, if a metal one came off then yes engine damage COULD happen
There are a couple of reasons to replace a water pump when doing the cambelt change, here are the 2 main reasons
1, you have the belt off so your halfway there
2, it is showing signs of play and or there is a poweredery dust on the underside, a sure sign the pump is letting a little coolant weep
For me the reason i change pumps is because when a belt is fitted you set the belt tension to the correct amount, as the miles stack up the belt slackens off a little, so new belt on at the right tension on the belt and there is now a water pump bearing under pressure again, also if a pump has already done 60k your dreaming if you think it will do another 60k without problems
Get it changed
one other thing, i dont care what anyone say's YES pumps do have a warrenty, so you fit a new OEM 2 yr warrenty pump, after 18 months the impeller comes free, YOU WILL ONLY GET A NEW PUMP, THEY WILL NOT COVER ANY LABOUR, they could even claim it was fitted and tensioned incorrectly and not even cover the water pump
Ive been in the motor trade for 20yrs, ive seen many claims for parts made and very few ever get paid out, use genuine, have it fitted properly and if the pump lets rip, best you can hope for is a new pump, a massive £24 TPS trade, not worth the hassel of finding the invoice TBH
2004 Golf 5dr TDI, 140 remap, GTI front bumper, skirts, highline cluster, 18in wheels, jamax coilovers, winter pack
WANTED HIGHLINE CCM AND CECM PLEASE PM ME IF YOU CAN HELP
  • -Given: 380
  • -Receive: 442
« Reply #9 on: April 22, 2012, 02:10:49 pm »
....Thanks, I now remember that being a reason.  :drinking:
