Author Topic: Yellow Fogs  (Read 3523 times)
Offline da_ansa
Yellow Fogs
« on: April 30, 2012, 02:32:33 pm »
Hello all, i was thinking of changing my fogs to yellow ones. i know its not to everyones preference but i would like to do it. i was just wandering if i can put any bulbs in or does it throw up an error on the ecu.
Many thanks
Offline mvb12
  • -Receive: 64
Re: Yellow Fogs
« Reply #1 on: April 30, 2012, 02:35:48 pm »
you use lamin-x tint
Offline da_ansa
Re: Yellow Fogs
« Reply #2 on: April 30, 2012, 02:37:52 pm »
ill go down the route then thanks
Offline nezquick
Re: Yellow Fogs
« Reply #3 on: April 30, 2012, 02:39:30 pm »
Like MVB mentioned lamin does the trick but if you want the real yellow look then you need bulbs or bulbs and tint - let me know which fog lights you have I have a set of bulbs going cheap (you either have the project ones or the normal everyday bulb ones)
**if you want the bulbs as well that is**
Offline da_ansa
Re: Yellow Fogs
« Reply #4 on: April 30, 2012, 02:41:36 pm »
how can i tell if theyre projector or normal?  (sorry if i sound stupid, i havent a clue atm lol)
Offline nezquick
Re: Yellow Fogs
« Reply #5 on: April 30, 2012, 02:50:33 pm »
Thats alright, If i'd bothered to ask I would be using the right ones by now!
these are the projector
these are normal
the difference is in the lenses (mainly)  :happy2:
  • -Given: 380
  • -Receive: 442
Re: Yellow Fogs
« Reply #6 on: April 30, 2012, 02:52:33 pm »
Which work best in fog: Yellow or clear?
Offline da_ansa
Re: Yellow Fogs
« Reply #7 on: April 30, 2012, 02:53:27 pm »
ill find out when i finish work and send you a pm
Offline nezquick
Re: Yellow Fogs
« Reply #8 on: April 30, 2012, 02:53:38 pm »
yeeeeeeeeeeeeeelllow  :happy2:
Offline nezquick
Re: Yellow Fogs
« Reply #9 on: April 30, 2012, 02:54:00 pm »
sounds good  :happy2:
Offline nezquick
Re: Yellow Fogs
« Reply #10 on: April 30, 2012, 02:55:17 pm »
Yellow, yellow cuts through the fog better especially thicker fog. if you google it there will be a load of scientific explanations. I believe its one of the reasons for the french using yellow fogs.
Offline Nodz
  • -Given: 73
  • -Receive: 103
Re: Yellow Fogs
« Reply #11 on: April 30, 2012, 02:56:39 pm »
Apparently yellow light is better for fog as white light reflects more on the fog (something like that)
Offline da_ansa
Re: Yellow Fogs
« Reply #12 on: April 30, 2012, 02:56:54 pm »
Are they legal?
  • -Given: 380
  • -Receive: 442
Re: Yellow Fogs
« Reply #13 on: April 30, 2012, 02:57:51 pm »
I wear yellow prescription specs when driving at night and on dark days or in fog and vision is improved. It also cuts the glare from other lights.
Offline nezquick
Re: Yellow Fogs
« Reply #14 on: April 30, 2012, 02:58:58 pm »
Are they legal?
yes mate
