Author Topic: ceramic brake pad set for golf v gti  (Read 4663 times)
Offline petrosgti
« on: May 04, 2012, 07:19:13 pm »
Hi
It's time to replace the front brake pad set and I think to put ATE ceramic pads instead of the other ATE classic.
The discs I have in front axle is zimmermann sport brake discs non ceramic in normal size (318x25).
Is this combination correct?
If someone has an opinion please let me say. :confused:
mk5golfgti for ever
Offline driver rider
  • -Given: 18
Re: ceramic brake pad set for golf v gti
« Reply #1 on: May 05, 2012, 10:23:40 am »
I'm by no means what I'd call technically minded but for me ceramics are only good for consistsent high speed driving.  Eveen then they rarely get up to operating temperature.  Theyre'really designed for track use and not for the road.  I could be wrong.
3 Door GTI Black, Cruise Control, DSG, Factory Tints, Folding Mirrors, Heated Seats, Highline Display, Leather, Monza II's, MFSW, Parking Sensors, Puddle Lights,  Xenons,
To be fitted....Bluetooth,DVB-T, MDI, RNS510, Stage one (opinions much appreciated)
Offline Thor
  • -Receive: 25
« Reply #2 on: May 05, 2012, 10:56:53 am »
I think a number of members are running the Pagid performance pads on here with good results.  I'm sure one of them will post up soon.
                                     Mk6 GTI
Offline petrosgti
« Reply #3 on: May 05, 2012, 01:33:10 pm »
I also have approximately the same opinion as you, but I read the article to the ATE site and i changed my mind. They also say that do for normal use
http://www.ate.de/generator/www/com/en/ate/ate/themes/10_products/10_friction-parts/15_ceramic/productinfo_ceramic_brake_pads_en.html
I'm still confused
mk5golfgti for ever
Offline Russ_leeds
« Reply #4 on: May 05, 2012, 03:34:02 pm »
I'm running the pagid rs4-2 blues in my NQSBBK and they're immense  :driver: although I don't think they're ceramic?
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
  • -Given: 380
  • -Receive: 442
« Reply #5 on: May 05, 2012, 03:37:43 pm »
I must say that the ATE web site does quite a convincing job of showing the benefits of their pads. Such CERAMIC pads may be the way forward.
  • -Given: 18
« Reply #6 on: May 05, 2012, 03:48:13 pm »
Looking at replacing my discs and pads was going to make a post asking if pagid are any good?  I was going to buy from eurocarparts.
Offline petrosgti
« Reply #7 on: May 05, 2012, 04:22:59 pm »
they have the double price but do triple km. Ι think seriously to buy it
and this article from the ate sait says that.....
<< ATE Ceramic is not a high-performance brake pad. It is designed for normal driving. Ceramic brake pads should not be confused with those made of carbon fiber (reinforced silicon carbide), which are used together with ceramic composite brake disks in high-end sports cars and luxury cars.
Ceramic friction materials consist of ceramic fibers, fillers, binding agents and mild abrasives, among other substances. Their typical characteristics are light lining material, low noise in braking, low wear and low dust generation.>>
mk5golfgti for ever
  • -Given: 380
  • -Receive: 442
« Reply #8 on: May 05, 2012, 04:27:59 pm »
....That sounds good. I don't think that anyone on this forum has used these ATE pads. People tend to assume high performance, track or trackday pads when they read the word "ceramic". If you get them we'll all be interested in what you think of them.
Yassou!  :happy2:
Offline tony_danza
  • -Receive: 112
« Reply #9 on: May 05, 2012, 04:33:44 pm »
I run Pagid RS29s in my daily, they're fine. Some of the lesser brands can be a bit sketchy when cold - ATE I'd trust implicitly, and the fact they're TUV approved adds to that.
Sideways yo!
