Author Topic: Black smoke and diesel smell?  (Read 9448 times)
Offline Snickers
« on: May 06, 2012, 03:48:09 pm »
I had the dpf removed from my 170 on Tuesday. It now chucks out alot of black smoke and I can also smell diesel inside the car. Is this normal?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Black smoke and diesel smell?
« Reply #1 on: May 06, 2012, 04:03:43 pm »
The black smoke is as that's all the particles that your filter would have caught. As for the diesel smell, sounds like you may have a leak  :sad1:
Offline AndrewJB
  • die gelbe Baron
« Reply #2 on: May 09, 2012, 05:38:31 pm »
its perfectly Normal
Hence why when you walk behind a bus it stinks of diesel
Who did your DPF Delete?
2014 Seat Leon Cupra 280 VWR Springs, VWR Intake, REVO Stage1
Online Andy
« Reply #3 on: May 09, 2012, 05:51:52 pm »
you shouldn't smell diesel in the car--not sure but the car might be remapping now the dpf is removed
Offline AndrewJB
  • die gelbe Baron
« Reply #4 on: May 09, 2012, 06:09:15 pm »
its common my PD170 did it aswell, the fumes coming out of the back of the car really stink, if the winds blowing the right way they come straight under the car and into it
few mates also had the same
Offline Snickers
« Reply #5 on: May 09, 2012, 06:21:38 pm »
Fr&r tuning. Only did a software remap to delete the dpf data. The ecu was not remapped for bhp increase. It does seem to smoke a lot though
Offline AndrewJB
  • die gelbe Baron
« Reply #6 on: May 09, 2012, 06:24:58 pm »
cr4p mapping then
ive had several maps on my car before i sold it, the last setup was the Stage2.5 from Shark
Shark also do a Stage 0 DPF Delete which is like you have got, that didnt smoke at all
Offline Snickers
« Reply #7 on: May 09, 2012, 06:40:38 pm »
cr4p mapping then
So if I were to buy their stage 0 map with an sts unit would that override the current map in the car and everything will run fine?
« Last Edit: May 09, 2012, 06:51:06 pm by Snickers »
Online Andy
« Reply #8 on: May 09, 2012, 06:42:21 pm »
best taking it to your nearest tuning place and get it done on the rollers
Offline Snickers
« Reply #9 on: May 09, 2012, 06:49:51 pm »
Thing is I don't really want to spend money on a remap to increase bhp as I'm happy with the current power. It was the dpf light that was bugging me and havin to go for a short blast on the motorway every week! Now the dpf issue is sorted it smokes a lot.
Online Andy
« Reply #10 on: May 09, 2012, 06:52:30 pm »
it sounds like it over fuel but a tuner will tell you better,they can just give the car a mild map,Dave at pdt or Nick at r-teck will advise you better
Offline PDT
  • -Receive: 142
« Reply #11 on: May 09, 2012, 08:05:03 pm »
See this a lot when we get cars in that have had their software created using a patch rather than a 'proper' dpf off solution.
A patch is a method of 'papering over the cracks' to eliminate the dpf light and dpf regeneration process. A better solution will alter a huge amount more, including torque limiters, smoke maps, boost maps etc.... But also cost more to carry out.
Offline Snickers
« Reply #12 on: May 09, 2012, 08:18:33 pm »
Would a remap sort this problem?
Offline PDT
  • -Receive: 142
« Reply #13 on: May 09, 2012, 08:24:16 pm »
If the person you choose has a good knowledge of DPF off then they could resolve the issues (as long as the ssues re software related and not an underlying fault)
I would advise you talk to the people that id the dpf off and discuss the issue, sometimes we need to re-visit DPF off jobs on some cars, but we cracked the siemens PPD system a while back now, but still get every DPF off we carry out to return after 7 days for a check.
Offline AndrewJB
  • die gelbe Baron
« Reply #14 on: May 23, 2012, 04:32:52 am »
cr4p mapping then
Shark would apply a new "Map" onto you car this map would contain the DPF Delete and OEM Mapping
Car wont smoke at all
i used my STS Device to switch my car (DPF Delete,EGR Delete and Straight Through Exhaust) from Stage2+ (Very Smokey) to Stage 0 and the car didnt smoke at all
of course i turned my map back a few minutes later  :grin:
