Author Topic: Difference between 16" and 17" alloys  (Read 2174 times)
Offline DarkSideJohn
« on: May 11, 2012, 01:38:15 pm »
Hey folks ,
Been looking around at some possible alloy upgrades as mine are in a bit of a bad state in some areas.
I currently have these...sorry i dont know the actual name , but they are just standard VW allows i believe
Which are currently in a 16" size
I've been looking around at the various options and build threads on many forums , a lot of people seem to favour 17" sizes , are there any actual benefits to this ?
Part of my seemingly ever growing "mods wanted" list is so better brakes , perhaps up to some 312mm's , would these even "fit under" 16" wheels
Im a bit of a dunce when it comes to most things , and as such appreciate all your answers , they all get filled away for when i actually pluck up the courage to get some stuff done !
thanks as always
John
'04 GT TDI 140 | Remapped | Cold Air Intake | WALK | TBE
Offline Oli
  • -Given: 19
Re: Difference between 16" and 17" alloys
« Reply #1 on: May 11, 2012, 01:58:11 pm »
1".......
Offline Moz
« Reply #2 on: May 11, 2012, 02:01:27 pm »
« Reply #3 on: May 11, 2012, 02:04:39 pm »
Yeh thanks guys that helped.....
I can see the sarcastic merit of what you did there , probably would of been inclined to do so myself ...but still doesn't help much
Offline gazon69
« Reply #4 on: May 11, 2012, 02:14:24 pm »
Hi mate, for a starters 17's will look better and fill the arches more, you will also have better grip under acceleration as the
17's would more than likely be wider hence more tyre surface on the road, also 17s would probably have a lower profile side wall so when going around corners the car would handle a little better as there wouldn't be as much tyre wall flex as with the baloons that are fitted to 16s. Cons are 17" tyres would be more than likely more expensive and you would also be sacrificing comfort as the lower the profile the more you feel the road. If i were you i'd shove some 18"monzas on. They would look loads better. Thats just my opinion though.
Offline dodds-gttdi
  • -Given: 22
  • Edinburgh
« Reply #5 on: May 11, 2012, 02:21:49 pm »
312mm GTI brakes under original VW 16" wheels:
With 17's you will feel roll in the car in corners. Plus the car will look better. :smile: with 17" alloys yo can fit .:R32 wheels under and the .:R32 came with the option of purchasing 17" winter alloys.
HTH
Offline Upperoilcan
« Reply #6 on: May 11, 2012, 02:41:00 pm »
If your going to upgrade your alloys do it properly and get 18's or 19's
17's really arnt that much of an upgrade over the 16's IMHO. :evilgrin:
« Last Edit: May 12, 2012, 08:12:51 am by Upperoilcan »
« Reply #7 on: May 11, 2012, 07:43:28 pm »
+1 go for 18 or 19"
Even 17" Monzas go for £200 or so.
« Reply #8 on: May 11, 2012, 07:46:28 pm »
mmm some body mention 19" wheels :innocent:
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #9 on: May 11, 2012, 07:51:43 pm »
Gets sum bangin 20" rims on ya ride bruv , go da hole hog  :evilgrin:
Offline skard
  • -Receive: 245
« Reply #10 on: May 11, 2012, 08:11:50 pm »
Have to say I love the look of the 17" ClassiX's I have compared to the original Imola(?) ones you have now.
