Author Topic: Fluttering noise on boost  (Read 4112 times)
Offline Ashley g
    • Durward's Autoshop
« on: May 12, 2012, 11:31:32 am »
Morning all. My car seems to be making a fluttering sound on boost. It's really noticeable when accelerating in 6th gear at around 3500rpm, sometimes in 5th gear too. I've just fitted a revision G diverter valve as the old one had a split diaphragm. It transformed the performance of the car but now notice the fluttering noise. Has anyone got any ideas? My mods are in my sig below.
Thanks in advance, Ash
2007 Edition 30, build number 30 - APR Stealth TBE - APR HPFP- APR stage 2 remap - Custom CAI - KW Clubsports - 10mm spacers on rear - VW Motorsport LSD, clutch & quick shift - A few poly bushes here and there!
*SOLD AND I MISS IT!! ANYONE SELLING A NICE ED30 PM ME* - UPDATE - I HAVE IT BACK!!!
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Fluttering noise on boost
« Reply #1 on: May 12, 2012, 12:03:48 pm »
Does it feel like the car is misfiring?
Offline Ashley g
« Reply #2 on: May 12, 2012, 12:06:58 pm »
Doesn't feel like a misfire, had new coilpacks fitted at VW this morning and checked the plugs which are only 1500 miles old
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #3 on: May 12, 2012, 12:11:35 pm »
Mine was fluttering and sort of hesitating (even after new plugs) at low revs under hard boost, so I reduced the gap on the spark plugs down to 0.67mm and it's spot on  :happy2:
Apparently high boost sort of blows the spark off the plug or something.
Lee M
« Reply #4 on: May 12, 2012, 09:24:12 pm »
Hi mate,
Fluttering noise is normal. My Cupra does the same thing. It's controlling the boost level and is a normal occurrence.  If its not effecting the drive then don't worry about it.
Cheers lee
Offline PDT
  • -Receive: 142
« Reply #5 on: May 12, 2012, 09:28:40 pm »
Hi mate,
Cheers lee
Flutter noise is usually caused by boost control, totally normal.
Offline Ashley g
« Reply #6 on: May 13, 2012, 10:04:19 am »
Ah so it's normal then? Where dies the fluttering noise come from? It's running the standard ngk plugs, what should these be gapped to?
Cheers for the help so far!
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #7 on: May 13, 2012, 10:39:05 am »
It's the pcv/diverter valves controlling the amount of boost...
Diesel Daily Hack.
Lee M
« Reply #8 on: May 14, 2012, 09:28:39 pm »
Hi mate. Yes normal function. I'm pretty sure plug gap is 0.8mm
Lee M
« Reply #9 on: May 14, 2012, 09:30:46 pm »
Saying that I'm basing that info. on my Cupra engine, so yours might not be the same
Offline alackofspeed
  • -Receive: 24
« Reply #10 on: May 14, 2012, 11:14:38 pm »
PCV - I hope not!
The PWM control of the n75 on a friend's 1.8t running a MBE had a very distinctive flutter from the exhaust. Relatively low frequency square waves it seemed, so it made distinctive pfft, pffft, pfft as it went down the road at full boost.
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #11 on: May 15, 2012, 02:05:10 pm »
sorry meant the n75 valve thingy... :innocent:
Diesel Daily Hack.
Offline Ashley g
« Reply #12 on: May 16, 2012, 11:28:23 am »
So it's totally normal for the N75 to make this fluttering sound then? Only I've never heard one make a noise before!
Offline john87
  • -Receive: 53
« Reply #13 on: May 16, 2012, 12:24:06 pm »
My gti does this under full boost, can sometimes hear the occasional flutter through the TWINtake  :happy2: no effect on performance!
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=prqp7ni3srb6soq7ub9edlitd5&/topic,19740.0.html
« Reply #14 on: November 12, 2012, 10:20:00 am »
FECK.... mine flutters like buggery with my intake on  :scared:
