Author Topic: K04 Turbo actuator  (Read 7032 times)
K04 Turbo actuator
« on: May 14, 2012, 08:19:25 pm »
Evening all.
Can this be accessed from the engine bay, or does it have to be up in the air?
Rich
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
Re: K04 Turbo actuator
« Reply #1 on: May 14, 2012, 08:21:46 pm »
I think it's a turbo off job to do rich.
I don't think it's advised to change for an uprated one from stuff i've seen/read if that's what your planning. I remember someone frying a K04 due to fcuking about with an uprated forge actuator :scared:
« Reply #2 on: May 14, 2012, 08:24:39 pm »
Ohhh no, not changing it, i just want to see if its loose.  :happy2:
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #3 on: May 14, 2012, 08:26:19 pm »
Turbo off job then  :happy2:
« Reply #4 on: May 14, 2012, 08:35:26 pm »
The pesky rattle?
« Reply #5 on: May 14, 2012, 08:37:23 pm »
The pesky rattle?
Yes Mike. Doing my head in now, it needs to go... or the car needs to.
Really Carl Turbo off?  :sick:
« Reply #6 on: May 14, 2012, 08:40:36 pm »
The pesky rattle?
Cant remember if you've checked DP/exhaust bracket that bolts to subframe? its a known weak point, mine used to rattle
« Reply #7 on: May 14, 2012, 08:43:16 pm »
Yeah ive checked that mate.
It might be new turbo time.  :sick:
If i want to accelerate i have to use full throttle otherwise i get a rattle.  :signLOL:
« Last Edit: May 14, 2012, 08:45:39 pm by richwig83 »
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #8 on: May 14, 2012, 08:44:03 pm »
Yes mate I'm afraid so.
« Reply #9 on: May 14, 2012, 08:45:48 pm »
Bad times!
« Reply #10 on: May 14, 2012, 08:47:03 pm »
hybrid or bust  :evilgrin:
« Reply #11 on: May 14, 2012, 08:50:26 pm »
Bust....
« Reply #12 on: May 14, 2012, 08:51:36 pm »
Boo  :sad1:
Offline chungster
« Reply #13 on: May 14, 2012, 09:01:16 pm »
It's right underneath the manifold when bolted up to the block so yeah turbo off I'd say!
Offline vRSAlex
  • -Receive: 253
« Reply #14 on: May 14, 2012, 09:13:34 pm »
You can access the rod and nuts to adjust it when the turbo is fitted.  I've had to adjust mine in the past.  I'm sure I could remove the whole actuator with the turbo still fitted.
Let's try that little clip mod Rich.  Worth a try before changing the turbo (for a hybrid)  :happy2:
Follow AKS tuning on Facebook
