Author Topic: K04 Turbo actuator  (Read 5917 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=v60hc5r6l01a4giluh3scf9qoj&/topic,19740.0.html
Re: K04 Turbo actuator
« Reply #15 on: May 14, 2012, 09:15:13 pm »
You can access the rod and nuts to adjust it when the turbo is fitted.  I've had to adjust mine in the past.  I'm sure I could remove the whole actuator with the turbo still fitted.
Let's try that little clip mod Rich.  Worth a try before changing the turbo (for a hybrid)  :happy2:
Ok Alex... how would friday work out? Late morning?
Offline vRSAlex
  • -Receive: 253
« Reply #16 on: May 14, 2012, 09:24:41 pm »
That will be fine :happy2:
Follow AKS tuning on Facebook
« Reply #17 on: May 14, 2012, 09:27:51 pm »
Cool, ill order that part (probably wont fit  :signLOL: )... ill be interested to see what you think of the noise Alex. Im convinced its turbo related even though it performs fine.
Offline vRSAlex
  • -Receive: 253
« Reply #18 on: May 14, 2012, 09:29:23 pm »
You want me to get it?  I can easily send it back if its no good.
« Reply #19 on: May 14, 2012, 09:30:09 pm »
If thats no problem? 06J145220A  (i think)
Thanks very much  :happy2:
Offline vRSAlex
  • -Receive: 253
« Reply #20 on: May 14, 2012, 09:34:27 pm »
I will order it in the morning  :happy2:
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #21 on: May 14, 2012, 10:47:09 pm »
what kind of noise is it?
Silver is the way !
« Reply #22 on: May 14, 2012, 10:57:28 pm »
Much appreciated  :drinking:
Its like a tinkling noise, sort of like a nut in a jam jar being rattled... but not as loud. It only happens on part throttle (25-50%) and when the car is warm.
Ive got a spare DV i need to try just to rule that out but i dont think its that.
Rich
Offline james
« Reply #23 on: May 17, 2012, 11:45:44 am »
Rich
mine makes that noise also, i thought it was norm lol.
« Reply #24 on: May 17, 2012, 02:39:51 pm »
Well mine has developed over the last 6 months or so, can't remember exactly when it started.
At least I'm not the only one James.  Hopefully Alex will be able to shed some light on what's causing it.
(Alex. You have a PM)
