Author Topic: Disaster :@ UPDATE  (Read 60413 times)
Offline biffobear
Re: Disaster :@ UPDATE
« Reply #180 on: May 26, 2012, 03:26:21 pm »
i think the clue here is that it was "pulling like a train right up to the red line", so it sounds like an overboosting problem, which on a quite high milage ? turbo would be the last straw and would end up drawing the oil out the engine and dumping it out the exhaust, best bet would be to check the turbo bearings and seals, or fit the old parts and start again. Bear in mind that,when you start it up again you will still be burning oil again, and probably oiling up the spark plugs until the oil deposited in the cylinders and down the   exhaust will take a while to burn off, good luck.
Offline edd666999
  • -Receive: 89
« Reply #181 on: May 26, 2012, 07:55:17 pm »
Why risk either damaging a 2nd turbo with a map that doesn't suit or potentially buying a dodgy turbo? If you go ko3 at least your at a point where you know it should work.
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #182 on: May 26, 2012, 07:57:44 pm »
Wise words...
Fit stuff you know was working... rule that side of things out...
Diesel Daily Hack.
« Reply #183 on: May 26, 2012, 08:45:58 pm »
Wise words...
....Exactly! Solving problems like these is a process of elimination.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #184 on: May 29, 2012, 03:37:00 pm »
Well Sammy How you getting on?
Silver is the way !
Offline apples12
« Reply #185 on: May 29, 2012, 04:37:03 pm »
um....
was this car ever mapped correctly after having the injectors swapped over?... whilst it did still pull right to red line?....
perhaps try getting your old injectors fitted, see what happens then...
if that cures things/settles things.... get your injectors fitted, granny it or get it over on a flatbed over to a reputable mapping company and get the injectors mapped in properly...
MK6 GT TDI  - CW - LUX pack
GONE
MkV Golf 1.9TDI Sport in DBP, 160,000 miles and climbing!
Retrofits by me:GT front end,OEM bixenons with auto-levelling/washers, Valeo LED Rears, MFSW + Highline SWCM, Cruise Control, 30byte Highline CECM, Highline clocks, Rain/Light Sensor, Auto-dimming Rear view Mirror, RNS-510 LED (Ver H; SW: 4020), Fiscon Basic Bluetooth, MDI + Aux, Armrest, Reverse Camera LOW, TPMS..what next...
Offline Sammy
« Reply #186 on: May 29, 2012, 04:40:35 pm »
Well I have planned on changing out the turbo first to see what happens, I will update if that cures anything if not injectors will be changed back to normal and if not that then I am well screwed
GTI MK5 with all the gooodies
K04 power going on soon!
Saintsteve
« Reply #187 on: May 29, 2012, 06:27:07 pm »
Let's hope your right or your wasting a grand ..
Offline Sammy
« Reply #188 on: May 29, 2012, 06:32:31 pm »
Yeah time will telll getting impatient now! Btw there was no fuel pump issue
Saintsteve
« Reply #189 on: May 29, 2012, 06:51:24 pm »
Let's hope for your sake.... It's only money
golf52
« Reply #190 on: May 30, 2012, 12:57:24 am »
um....
apples12, can you please contact me. dirktiers@yahoo.de
« Last Edit: May 30, 2012, 01:04:33 am by golf52 »
Offline R-tech-Nick
  • -Receive: 30
    • R-Tech Performance Tuning
« Reply #191 on: May 30, 2012, 08:57:33 am »
Like I said before by fitting the S3 injecotrs the car would have been save to drive normally to get to a tuner as the B1S1 would work open loop and trim the injection to keep the lambda with in range.   I am still convinced its down to the turbo side of things, when I spoke to Sammy on the phone he did mention he had some good spirited runs under full boot..... what the full boost number was no body knows.
 But put it this was I had a celtic tuning Stage 1 ED30 in the other day with an agressive N75 I-pilot map (like the K03 stage 2 tuned N75 maps) and his car was boosting to 29psi  it ease and making 408lbft.
If your going to add bigger turbo / injectors ect...  then just add a little common sense  before getting the car mapped.
R-Tech Performance Tuning & Rolling Road Centre
Custom ECU Remap Tuning Specialists
1.8T - 1.9TDI - 2.0TFSI - 2.0TDI - DSG
Hinckley Leicestershire LE10 3BY
01455 617233
We aim to be the best not the biggest!!
8AD1691 - 1000101011010001011010010001 - 8AD1691
www.sticky-vnt.co.uk www.removal-dpf.co.uk
Offline Sammy
« Reply #192 on: May 30, 2012, 02:16:15 pm »
I am quite convinced it is the turbo too and changing it out, will update once changed
« Reply #193 on: May 30, 2012, 07:57:40 pm »
Fingers crossed it works
Offline martziniuk
« Reply #194 on: May 30, 2012, 08:14:25 pm »
Make sure you give it a good thrashing to be sure it's fixed  :grin: :wink:
Mk2 Octavia vRS with K04 conversion, 3"TBE & Decat, APR HPFP, BDM Intake, S3 I/C, Sachs clutch & Unicorn custom map, S3 brakes, AP coilovers, THS mounts.
B8.5 Audi S4 with uprated pulley and unicorn Stage 2
