Author Topic: Tesco 99 Ron  (Read 22016 times)
Offline Dp_Ed30
Re: Tesco 99 Ron
« Reply #30 on: June 06, 2012, 10:13:52 am »
i use v-power most of the time but tescos 99 near the end of the month when im skint ( tesco pay at pump lets you fill up a full tank even if you only have a few quid in the account :grin:)
went for a country lane run on sunday and found myself 60miles from home with the fuel light flashing, only station i could find had 95ron, stuck some in and set my car to 95ron map and i was shocked, car felt flat, boost felt lacking and overall no were near the power it makes on 99 :driver:
Re: Tesco 99 Ron
« Reply #31 on: June 06, 2012, 10:24:05 am »
Apparently, if tuned for V-Power/99 and you have to fill with 95 RON, it will take a good half tankful or so before you will feel the inferior results.
Offline Dp_Ed30
Re: Tesco 99 Ron
« Reply #32 on: June 06, 2012, 10:28:34 am »
i found it was a instant drop, maybe had more to do with me dropping to apr 95ron map, with such a diffrence i cant wait to go from 99--->104 ron  :jumpmove:
Re: Tesco 99 Ron
« Reply #33 on: June 06, 2012, 10:30:31 am »
Yep, gotta be due to dropping to the appropriate map - Your experience actually proves the difference!
Re: Tesco 99 Ron
« Reply #34 on: June 06, 2012, 10:44:22 am »
Not exactly. If, due to the fuel, it can't run such high timing, boost, etc it will correct instantly rather than give pinking or knock or leave the engine running at dangerous levels.
That's what these engines do.
Offline Baz300
Re: Tesco 99 Ron
« Reply #35 on: June 06, 2012, 05:17:11 pm »
Im thinking it is a problem with the shell station that I use near work it's more expensive than another shell just over a mile away but I normally just use it because it is handy.
I filled up at the other shell and the car feels the same as It did with the tesco fuel!
I won't be using the shell station near work anymore unless I really have to
Offline Lone_Par
Re: Tesco 99 Ron
« Reply #36 on: June 06, 2012, 06:20:09 pm »
Which shell is that mate?
Offline Baz300
Re: Tesco 99 Ron
« Reply #37 on: June 06, 2012, 06:21:28 pm »
The one at the airport
Offline Lone_Par
Re: Tesco 99 Ron
« Reply #38 on: June 06, 2012, 06:24:05 pm »
I tend to use the one in Bucksburn as its en route to town - no issues there but I do think my car is running better and more economically using the Tesco. Do have to go to Westhill though as the Inverurie Tesco doesn't do momentum.
Offline Baz300
Re: Tesco 99 Ron
« Reply #39 on: June 06, 2012, 06:31:06 pm »
It's the one in bucksburn that I'm using now, I would use tesco but only really go near them when I go into town.
The Inverurie tesco is annoying as they have signs up for momentum but none at the pumps, would be very handy if they did!
 The shell just outside Alford has v power
Offline vRS_Pagey
  • -Receive: 59
Re: Tesco 99 Ron
« Reply #40 on: June 06, 2012, 06:38:30 pm »
I use Murco 95, is that any good?  :popcornsoda:
....When I see a brand called Murco I think murky and something too unsavoury to use for finely tuned automotive porn.
Like button required for this post!   :star:
Offline reflex11
Re: Tesco 99 Ron
« Reply #41 on: June 06, 2012, 07:15:34 pm »
some shell stations are privately owned, I tend to stay away from those :D
Re: Tesco 99 Ron
« Reply #42 on: June 06, 2012, 07:33:25 pm »
....How can you tell which ones are privately owned?
Offline Nodz
  • -Given: 73
  • -Receive: 103
Re: Tesco 99 Ron
« Reply #43 on: June 06, 2012, 07:42:37 pm »
Instead of having a shell shop they have a budgens or spar or sell things you wouldn't have in a normal shell garage
Offline Lone_Par
Re: Tesco 99 Ron
« Reply #44 on: June 06, 2012, 09:06:23 pm »
Yeah, found that out about Inverurie when I pulled in because they had the signs up - parked next to a pump and it was just 2 pumps of bog standard unleaded!  :fighting:
