Author Topic: Seat belt alarm issue...anyone help  (Read 12502 times)
Offline skard
  • -Receive: 245
Re: Seat belt alarm issue...anyone help
« Reply #15 on: May 28, 2012, 10:34:11 am »
Should it not be 0001403 minus chime?
« Reply #16 on: May 28, 2012, 10:35:02 am »
Worth a try...  :happy2:
Offline bacillus
  • -Receive: 451
« Reply #17 on: May 28, 2012, 10:40:49 am »
If you post a screenshot of your long coding helper like the one Richwig posted we may get a better idea of what to change.
« Reply #18 on: May 28, 2012, 10:44:39 am »
If it's 03403 then it becomes 01403 simples.  :smiley:
Saintsteve
« Reply #19 on: May 28, 2012, 10:53:26 am »
best i can do..   :ashamed:
« Reply #20 on: May 28, 2012, 10:54:37 am »
So
0001403 as has been mentioned above  :happy2:
Offline ktlstar
« Reply #21 on: May 28, 2012, 10:57:29 am »
I would put the 3 into a 2 and try it, i did this last night and it worked IIRC the figures.
« Last Edit: May 28, 2012, 10:59:27 am by ktlstar »
- #1240 ED30 Revo STAGE2+
- Southeast - Vag Com owner
« Reply #22 on: May 28, 2012, 11:00:10 am »
Nope... thats not right.
Offline ktlstar
« Reply #23 on: May 28, 2012, 11:05:14 am »
Yup you are correct, just double checked my car same values. dunno where i got them values from then lol.
« Reply #24 on: May 28, 2012, 01:17:44 pm »
However I do have to question the wisdom of coding out an intermittent fault.  :confused:
« Reply #25 on: May 28, 2012, 01:20:17 pm »
If it were engine/airbag related then I totally agree. But in this case safety isn't an issue.
Saintsteve
« Reply #26 on: May 28, 2012, 01:37:35 pm »
I've given all the looms a tug,and replugged them back in, just have to wait till Swmbo to sit in the seat to test  :happy2:
« Reply #27 on: May 28, 2012, 01:43:30 pm »
Not mine at least.
There is a fairly common problem with the underseat wiring on Golf's and Octavia's. My early Octy had some wires replaced.
Offline Meallbhan
« Reply #28 on: May 28, 2012, 04:02:16 pm »
Disconnect the 2 pin plug under plastic cover under seat
Job done
+1, this worked for me too.  The wee box under each seat, just pull the plug.  This was the advice VW gave me and it works with not problems with MOT and airbags etc.  All these codes etc seem a bit too complicated.
Saintsteve
« Reply #29 on: May 28, 2012, 04:04:01 pm »
Not mine at least.
Could of been worse, imagine if it was a fast car... Abit like brakes  :popcornsoda:
