Author Topic: Need help urgently.  (Read 5044 times)
Peskarik
Need help urgently.
« on: November 18, 2008, 01:23:10 pm »
Hello, people!
This is my first post here, and it is not a happy one.  :sad:
As some of you may know I have my E30 remapped by Oettinger to 305hp/410Nm. It is just the map, no mechanical mods.
Two weeks ago I crashed into a van, and my front was destroyed, and radiator leaked out. A VW service station fixed everything, replacing the bumper, the hood, some parts from the radiator, and whatelse.
After that I tested the car, and obviously the map was deleted.
I went to Oettinger yesterday, and they did a remap again, the boss showed me an automatic email that they get when remap is done, and it read OK. I also asked them to put a sport filter in the original air box, which they have done (it is a non-oiled filter).
The problem is, the car does not feel 305hp strong. It does not have the airliner acceleration from 3000rpm that I felt before the crash. It feels like a 230hp car, despite the OK readout of the map burn.
I asked the boss of Oettinger shop, who did the remap, what should I do.
He told me to go to a VW service and ask them what the problem is. Specifically, he wrote the following:
"...they should check charge and the memory read error.
Perhaps this is also a boost pressure hose not properly mounted. There can be several causes."
So I wonder what I should do now?
Any suggestions what the problem could be?
I mean, if pressure hose is wrongly mounted, should not I be losing pressure even on 230hp car?
Can they measure charge without rolling road? What is memory read error?
I am concerned, don't know what to do. I have enough problems with interior rattling like unoiled cart, and now this...
THanks guys/girls in advance for help!
Re: Need help urgently.
« Reply #1 on: November 18, 2008, 01:37:32 pm »
A decent rolling road technician should be able to identify leaks etc. When Robin had issues recently a VW Specialist did this for him with help from the RR. Surley Ottinger should be able to offer you this service?
Welcome to the site BTW Pesky  :wink: :happy2:
Peskarik
« Reply #2 on: November 18, 2008, 02:17:06 pm »
That is what I thought also, that paying over 1000 quid for remap and coming for that remap 140km one way would provide me with some more customer service. They'd be happy to install suspension and whatever (since they make money), but for that problem they send me to VW service. ..
SOme other tuners I asked for prices for things did not even reply to my mails! I guess unless you own a Porsche and are prepared to spend thousands you are not important enough to have your emails answered.
« Reply #3 on: November 18, 2008, 02:31:11 pm »
Exactly as Greenouse says - You need a technician who knows what he/she's doing (oettinger tech would be perfect!) to data log how your car is behaving. Btw, I also had help on my problem with advice from Revo HQ.
Being down on power sounds very likely to be due to a very small boost leak of some sort. It could be the result of your accident and anything from a very small crack in the manifold&turbo unit to a hose connection or pinhole. If it was a bigger loss of power the cause would probably be much more obvious.
I'm currently in the middle writing a more concise topic about the problem I had.
Offline bacillus
  • -Receive: 453
« Reply #4 on: November 18, 2008, 02:44:25 pm »
If they removed the radiator from the car then they would have had to disconnect the IC hoses.
My guess is the IC hose clamps have not been properly retightened leading to a boost leak.
Peskarik
« Reply #5 on: November 18, 2008, 05:06:25 pm »
The accident was not very serious, the bag did not even go off, speed was about 40kmh. IF there is a crack in the manifold or turbo, that could be serious, no?  :scared:
I went to the VW dealership that repaired my car, they connected it to a computer (is that Vag Com?) and then they said everything is OK. The technician went out for a ride and he said car runs better than original. Maybe it runs better, but it does not run as it used to run before the accident, it does not have that explosive acceleration after 3000rpm.  :sad:
Offline neg
  • gone old skool
« Reply #6 on: November 18, 2008, 05:36:18 pm »
A boost leak wouldnt always log a fault  - so once again if the "computer says no" the technicians might say there isnt a problem when there is...
Maybe you dont feel it under the stock map as the boost is not as high.
« Reply #7 on: November 18, 2008, 05:50:43 pm »
As I understand it, a small but nonetheless important boost leak won't throw up any fault code but the data logs (laptop attached while running) will show the % effort the turbo is having to make to compensate and that can be an indication of a boost leak if the % is high.
« Last Edit: November 18, 2008, 06:09:57 pm by RedRobin »
Offline bacillus
  • -Receive: 453
« Reply #8 on: November 18, 2008, 06:06:50 pm »
I suspect the technician went for a spin without a laptop attached to the car relying only on his butt dyno.
Peskarik
« Reply #9 on: November 18, 2008, 07:39:21 pm »
he did...
