Author Topic: Remote Fob doesn't take up the windows.  (Read 3183 times)
Offline driver rider
  • -Given: 18
« on: June 04, 2012, 05:38:57 pm »
Hi,
my key doesn't wind up the windows when the are down.  They worked on my polo but they don't work on my GTI.  :ashamed:  Have I missed something?
3 Door GTI Black, Cruise Control, DSG, Factory Tints, Folding Mirrors, Heated Seats, Highline Display, Leather, Monza II's, MFSW, Parking Sensors, Puddle Lights,  Xenons,
To be fitted....Bluetooth,DVB-T, MDI, RNS510, Stage one (opinions much appreciated)
Offline skard
  • -Receive: 245
Re: Remote Fob doesn't take up the windows.
« Reply #1 on: June 04, 2012, 05:46:54 pm »
Did they previously work and you've disconnected your battery?
Manually one touch them down keeping a hold of the switch, then keep hold of switch as it goes up, and then try from the remote.
  • -Given: 18
« Reply #2 on: June 04, 2012, 05:51:44 pm »
Thanks for prompt reply.  I have disconnected the battery.    Sorry just to be clear do you mean I should hold onto the switch as I wind the window down and do the same as I wind the window up and then try the remote fob afterwards?
Offline skard
  • -Receive: 245
« Reply #3 on: June 04, 2012, 05:53:41 pm »
Yeh keep the switch depressed all the way and for at least a second after fully opening/closing, then try the fob.
  • -Given: 18
« Reply #4 on: June 04, 2012, 05:55:43 pm »
Okay.  Im currently at work (got to pay for the mods I've got lined up) then I'll try it!
vw55raz
« Reply #5 on: June 04, 2012, 06:04:12 pm »
may need activating using vcds. Anyone with vcds can do this for you.
Offline da_ansa
« Reply #6 on: June 04, 2012, 07:16:05 pm »
sorry to jump on the thread but is the drivers side window meant to come up automatically if you hold the switch up like it does when you hold it down
Offline suave
  • -Given: 31
« Reply #7 on: June 04, 2012, 07:35:39 pm »
Sorry but is remote fob windows up standard on our GTIs or do I need to pre programme mine for this?
If it is standard how does it work?
Offline da_ansa
« Reply #8 on: June 04, 2012, 07:46:54 pm »
don't know if it's standard but to put them down press and hold open on the key fob vice versa to close them
  • -Given: 18
« Reply #9 on: June 05, 2012, 09:14:58 am »
As far as I know it is suppose to.
I think I need it may need activating with vcds.  How do I find someone to do this for me?
Offline vwrascal
« Reply #10 on: June 05, 2012, 09:20:34 am »
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
  • -Given: 18
« Reply #11 on: June 10, 2012, 01:57:31 am »
Cool, thanks I'll get onto this....so much to do so little time...
Offline skard
  • -Receive: 245
« Reply #12 on: June 10, 2012, 11:51:55 am »
Did holding the window switch down, then up, not work?
Takes seconds to try.
  • -Given: 18
« Reply #13 on: June 10, 2012, 01:18:10 pm »
sorry I thought I responses to that post.....my mistake. I did try it the moment I left work but no luck.....though I'll try it again just for good measure.
Thanks again.....
Offline skard
  • -Receive: 245
« Reply #14 on: June 10, 2012, 02:21:35 pm »
Have you got a Highline cluster (full size screen on clocks) and MFSW (buttons on steering wheel)?
If you have then try get into the Convenience Menu and see if there is an option to reactivate them.
