So I stuck some new bits on !
The Brakes were sent to Jonny & DaveB @ brake caliper refurbs, the quality was WOW
Perfect!
S3 rears
To help keep the front brakes cooler, new bearings fitted at the same time
All cleaned then freshly painted with VRT heat paint on the fronts
Then baked for a short time in the oven
Plenty of room behind there
A set of s3 rear to pair up with the fronts, just to keep it all even
Rears painted
Carbon fibre braided lines all round
That was the brakes, now on to the suspension
VWR KW's fitted
Great job, lowered enough for me, still with a bit to go!
Popped the old white line WALK out, and in with super pros Anti lift Kit
As you can clearly see the difference!
The new superpro camber adjusters fitted at the same time
the whole car has now been superpro'd!
A few bags missing, but they all arrived and fitted
ARB's front & rear From White line thanks to Rob @W8 performance for sourcing these for me and the bushes and a few other things.
Sub frame out new bits fitted in, while it was out, it got cleaned up and some polish to help keep everything lasting longer
Some nice new red top coil pack thanks to Alex !
Whilst the sub frame was out, my exhaust needed re-wrapping, so we also found it needed re-welding around the gasket area
so re-welded cleaned and wrapped with titanium heat wrap
painted and left to dry thanks to Tim
Highline dash now aboard
Could not resist
Had a play about in this for awhile
Had to re-new this puppy here, not the easiest jobs to ever want to do, but it fixed the problem
Clutch picture!
Gear linkage holders
Then on the rollers for a bit of tweaking @ Auto tune
I'm sure there has been a few things missed, but when I remember I will fill in the blanks...
It's almost to the way I want it...
