April 14, 2025, 05:12:12 am
All Things Mk5
Members Rides
Golf Rallye 2.0 TFSI + Haldex 2gen
3
17
Topic: Golf Rallye 2.0 TFSI + Haldex 2gen (Read 119942 times)
2fast4you
Always Involved
-Given: 6
-Receive: 4
Some drive to work... I work to drive!
July 09, 2012, 12:12:48 pm »
Ok here is how everything went :
I own a Golf Rallye and I'm starting a engine swap. I have my eyes on an 2.5 tfsi engine from an Audi TT RS witch I haven't found yet but I will.
This are the parts that I already bought. Because my Rallye had a bit of rust on the front wing I had to find a new one
and I bought spare front and back fender
Haldex gen.2
ABS and the pump from a Golf 5 R32
Another spare pair of headlights
Dashboard from an Audi A3(leftover from the previous project)
Prop shafts:
one from Audi TT and another from a Golf 5 R32
And some more parts have just arrived
Recaro Speed seat
tail lights:
and the steering wheel
Going on with the dis assembly
I am removing the paint because I'm looking for rust and I was thinking to be repainting the body in tornado red
or maybe...
2fast4you
Always Involved
-Given: 6
-Receive: 4
Re: Golf Rallye 2.0 TFSI + Haldex 2gen
Reply #1 on:
July 09, 2012, 12:14:13 pm »
I bought these wheels
But I figured that those wheels are too big so I bought the OZ ultralegera 17x8 5x100
I thought these are the wheels for my project
What do you think?
I have stopped removing the paint because when I'm done with everything I will take the body shell to sanding and let the professionals do their job.This is what I am doing right now.
And started fitting the MK5 dash
and modifying the rear axle to except the Haldex 2nd generation
first taking measures
then cutting and starting the fitting
the first holder
and bought a pair of front and rear Brembo brakes from a Touareg
here is to see how much space is the gen.2 haldex is going to take
and the work that has been done around the fitting of the dash
first of all I bought a new subframe
and the original Golf 5 holders that the sub frame is tighten to and cut them to fit
then more cutting
and then started making some pieces to weld on the chassis that would except the holders for the sub frame
after I welded the holders I cut the rest of the sub frame to fit between the pieces
took the sub frame to be welded and here are the results:
and...
after the sub frame was fitted next was the intake for the air conditioning
first I took a part of the air conditioning to be a little modified
and then everything could be welded
After all of these I had to redo the shifter because it had to move 2 sm back ( it was too close to the dash)
Then bought these
Brembo
4 pot calipers because I've mounted the other ones that I had on the
Audi S2
project that I've been working on so the
Rallye
gets them brand NEW.
2fast4you
Always Involved
-Given: 6
-Receive: 4
Reply #2 on:
July 09, 2012, 12:19:17 pm »
finished painting the Brembo's
and this is how they look now.
opened the hole for the MK5 Heating
and done the engine mount
and something very important to me is that finaly I finished my garage. When I started mu project I got some comments saying "that's a creepy garage"
Well lets see how you like it now
Then some parts (of the many that I ordered) arrived so here they are:
The front disc 323x28 punched from Seat leon Cupra
and here they are with the BREMBO's
OMP Competition Belt 3", 4 fastening points x2
and more to come
the powerflex for the front axle
I also ordered adapters for the brembo and been waiting for them for a month. They newer came, so I email ed the firm that I bought the adapters from and they told me that they haven't sent them yet
because they are inserting some new features on them
In the mean time I will be painting the complete front Axle with the control arms
And some more parts
The front axle was sandblasted covered with primer, painted and finally assembled
bought a steering rack from VW Polo 9N and the servo motor
2fast4you
Always Involved
-Given: 6
-Receive: 4
Reply #3 on:
July 09, 2012, 12:20:35 pm »
and the Brembo Adapters came finally after 2 months of waiting
and after I had all the parts in one place everything started to come together as it should
and I must say that I've had help from Mario. You must ask you're self "who the f..k is Mario"
Well Mario is the guy who's car was the inspiration for me to begin with this project, you can find his project a MK2 golf with a 2 liter TFSI engine and doing a very good job
here is a link of his site where you can find some info and pictures of Mario's Golf.
http://www.golf2tfsi.de/html/home.html
I think he is watching this thread so I will use this chance to thank him for his help "THANK YOU MARIO"
Although I'm not finished with you I will need some advices in the future
I'm getting ready to finish up some minor things around the dash and start building a Roll cage. In the mean time the only part that was ordered, and arrived were the
H&R triple C chamber bolts
I'm just about to finish up the rear axle
This is how the rear axle looks:
one of the things I need to finish are these for Camber/toe adjustments
I bought these from my local VW dealer they are from Audi RS6 rear axle, you can find them on the ETKA as part number:WHT001682
that is if anybody needs them. All i need to do now is to make camber/toe plates. If you want these all done you can find them on this site:
http://www.dutchbuild.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=87&category_id=15&option=com_virtuemart&Itemid=104&lang=en&vmcchk=1&Itemid=104
gathered all the screws and nuts including the ones needed for the chamber adjustment and took them to be chromed.
and how they turned out
not perfect but OK
OK finally came the last parts that I needed to finish the rear axle.
Powerflex
And these are the rings and the bonded aluminum bush that I need to finish the mounting points on the axle. There are going to be 4 mounting points something similar to the factory rear axle from golf Mk5 4 motion
and the piece between the rings is an adapter that I need to combine the Golf Mk5 brake master cylinder and the 94 Passat VR6 brake and clutch pedals. And when these piece is welded it should look like this:
I also took the rear axle holder to be chromed
the Roll Cage from OMP arrived :
2fast4you
Always Involved
-Given: 6
-Receive: 4
Reply #4 on:
July 09, 2012, 12:21:57 pm »
... so the work continues
I finally found a Lancia delta Integrale hood
Here are some pictures
I was looking foe these hood for a ling time and finally found one :peace:
finished installing the roll cage
. The roll cage needed some modifications to accept the Golf 5 dash but finally it's done
Here are some pictures:
And here is the support to the suspension housing from the roll cage that I planed on doing
What do you think?
finished the rear reinforcement
also finished the front reinforcement from the suspension housing to the roll cage
so moving forward with the project
Today I finished modifying the tunnel to receive the Golf MK5 selector mechanism .
Started by cutting a bigger hole for the selector mechanism and drilling holes to get it fixed:
the small holes were made to remove the MK2 selector mechanism mounts
did some modifications on the tunnel to fit the MK5 selector mechanism
and here is how it came out:
in the mean time I mange to find time to build this :
so I can move the shell in mu garage
and some shopping was done:
Rear 4 piston calipers from Shevrolet Camaro SS 2010+ for the rear axle
brake disc for the rear :
also bought H&R FRONT SWAY BAR VW GOLF 3 VR6 25MM
and the emblems:
Finally finished the roll cage
2fast4you
Always Involved
-Given: 6
-Receive: 4
Reply #5 on:
July 09, 2012, 12:23:09 pm »
also sorted out the pedals
and the most important thing for me, the gearbox mount
still some minor things to be done and then... off to the paint shop
Then I remembered that I have something that could help me... a 4 motion DSG gearbox
from the looks of it everything should be OK
but will see.
the interior has been cleaned of the isolation and primed
the gas pedal has been installed
the ABS pump was also installed
installed the handbrake
and the upper reinforcement fixing screws
finished the fuse box:
there are only 2 things to finish now and off to sandblasting and then directly to painting
Sand blasting done and off to the Paint shop
I took the bumpers to be fixed. I closed the holes for the fog lights and filed in some bumps and cracks
Finally something done on the car
Closed the gas tank cap
The place for the battery
and the rear lower reinforcement
something more coming up !!!
2fast4you
Always Involved
-Given: 6
-Receive: 4
Reply #6 on:
July 09, 2012, 12:24:20 pm »
Today arrived some new parts that I ordered:
Porsche 944 door handles
and the front Rallye grill without a VW logo from Mattig
The roll cage and the rear axle were put in filler and after that the rear axle was painted:
Installed the Haldex
and one of the drive shafts
That is all for now
Because my car is at the paint shop I havent done no progress. But I have upgraded mu garage "TUNING GARAGE" as I like to call it ;)
A new ELECTROMECHANICAL 2-POST AUTOLIFT from WURTH (OMCN)
Finally the car has been put in first hand filer... and looks nice :p
The hood is almost finished. It took a lot of thinking and work but it's almost done :D
and the parts that I bought 3 months ago from U.S finally arrived
the rear calipers
and the H&R sway bar
And finally the hood is finished :)
everything fits as stock. All the lines are aligned :D
Audi R8 Calipers
now to figure out how to make the brackets :banghead:
Also the front end of the Rallye got together and now its time to correct every line that needs correcting and realigning ;)
The car was sanded and put in second hand filler
the bumpers:
closed one of the holes for the front wind screen wipers and the rear one also
2fast4you
Always Involved
-Given: 6
-Receive: 4
Reply #7 on:
July 09, 2012, 12:25:31 pm »
Did some shopping:
a set of Bi-xenon headlights from golf 5 to use the lenses with the shutter on the Rallye headlights
I bot my self a co pilot *
I was going for the antenna but why I bot the navigation I really don't know :(
a Quattro gearbox
and an MC from Audi TT RS 25.4 mm clip
Moore new parts
I was thinking for a very long time what to use for my gearstick and this is the answer
R pedals
Clutch cylinder
Front Audi TT RS brake lines :banghead: I tough they were steel braided but I guess I will be buying Braided ones :(
the pads for Brembo handbrake calipers
finally the MC with the brake fluid tank and the Clutch pump
I also bought a set of 4 Audi RS4 injectors which I will use with the stage 3 or 4 ;D when I buy an engine of course :D
I also got my garage a little fixed up and cleaned ;)
OK so here is some work done. Finally we started painting :facepalm: The interior and the engine bay have been painted and in the next few days so should the outside ;)
And some more parts:
APR HPFP
Audi S3 IC
and a NS MKV Offset Dashpod from ECS
Audi R8 fuel pressure valve
Audi Oil Cap
and the first thing I will change on my 2.0 TFSI
also updated mu garage with looks and some tools ;)
The only thing that wories me is the size of the IC. It's a bit taller then the Rallye IC ?
but I think I'll find a solution :dontknow:
Finally :D Some paint and clear coat
Only one thing I have to say:
Just the naked eye can see the real beauty of the finish :cool:
2fast4you
Always Involved
-Given: 6
-Receive: 4
Reply #8 on:
July 09, 2012, 12:26:25 pm »
Also sone more parts arrived:
I bought NEW all possible screws
and a special ??? thing that goes underneath the fixing points of the front fenders
and another styling detail
Finally after 10 months the Rallye is back in my garage;)
I didn't know where to start :rolleyes: I was all over mu garage taking out the parts stashed for the Rallye
Well the assembly has started :)
And tinted the windows
More parts from the shopping list have arrived
OMP Steering wheel
My racing shoes Alpinestars
Carbone Lorraine brake pads for my rear Camaro SS Brembo Calipers
and some more parts from the VW dealership
The bumpers, rear view mirrors, front grill came back from painting :cool:
I decided to chrome all mu nuts and bolt so here are some of that:
and more new parts
then started cutting the MK5 dashboard ;)
and at the end I finally installed the brake lines :thumbup:
I painted the front lock carrier, lower cross member and completed the front end and the bonnet because I couldn't wait to see how will the car look at the end
I got the bolts and nuts from the roll cage and the door locks chromed :)
bought some cardan shafts (Golf Mk5,Golf mk4,Audi TT 8n)
and glued the dash back together
and then cut and glued the other parts that needed fitting
2fast4you
Always Involved
-Given: 6
-Receive: 4
Reply #9 on:
July 09, 2012, 12:27:18 pm »
and at the end how should the interior look like
only maybe without the navigation ;)
Well finally I received the last batch if nuts and bolts that went to chroming
and so the work can continue
mounted the front and rear axle, and started on the measuring the propshaft
so everything looking good :rock:
Made the propshaft bolt on the original Rallye propshaft holders ;)
I also did a little intervention on the rear axle because the propshaft was a bit off center :banghead:
then unscrewed the fenders and put a special plastic sealant strip that I bought from the dealer
and then screwed them back on with the new screws and special intermediate zinc plates (they are used so you don't scratch the color ;) )
then installed the drivers seat :) . The codrivers will have to wait because I haven't received the seat rail for the seat :banghead:
after all of that I assembled an BWA engine that I had in mu garage with the quattro gearbox and fitted that on the Rallye
there is enough space for a GT3076 I think
and from under the car
there is one problem that will need to be solved :rolleyes:
the gearbox as fitted is very close and will hit the front axle
and when the car will be on its wheels ...should look something like this:
then the oil pan will be around 11sm from the ground
Dont know if it will be a problem
as you can see its almost the same height as the front axle
The lower engine mount finished
and the roll cage painted and half mounted :D
Still waiting for the big update :banghead:
And finally :D:D:D:D:D:D:D
My big update :D:D:D:D:D:D:D
Today I bought this:
a 2010 Seat Leon Cupra R
and the hart for the Rallye
Today I did little work on the engine, because he had same damage:(
Changed the intake manifold mounted the APR HPFP and valve ....
Nothing much done on the car at this time
I tried to clean the gearbox but couldnt so I sandblasted it ;)
installed a new hydraulic clutch pump
then installed the gearbox on the engine and in the car it goes
I started conecting the water hoses and other stuff to see what needs to be modified
and when I came to the gear selector
I had to drill some nasty holes to get that thing in the right position and length. I used the Audi TTs gear selector because as far as I know it has the longest cables
and it will be tight on the front end but I think I will manage to get the S3 IC and water cooler in there. If the MK5 GTI water cooler fits in there I was thinking of ordering the Mishimoto one and the Mishimoto fans
SORRY IF THE TEXT DOESN'T MAKE SENSE BECAUSE THIS IS COPIED FROM THE POSTS OF ANOTHER FORUM... BUT I HOPE YOU LIKE MY BUILD !!!
markymark
Just look at my post count
-Given: 21
-Receive: 55
Reply #10 on:
July 09, 2012, 01:22:48 pm »
Awesome work, cant wait to see the end results!
jameelno1
Always Involved
-Given: 16
-Receive: 8
TDI Power
Reply #11 on:
July 09, 2012, 01:41:10 pm »
this cars gonna be stupidly fast nice bit of work there
golf mk5 1.9 tdi
edd666999
-Given: 24
-Receive: 89
Reply #12 on:
July 09, 2012, 02:05:09 pm »
just
xjscx
Taking part
-Given: 3
-Receive: 0
Reply #13 on:
July 09, 2012, 02:14:12 pm »
Awesome
sub39h
-Given: 189
-Receive: 84
Reply #14 on:
July 09, 2012, 02:14:39 pm »
wowowowowowowowowowowow
MODS
: '09 tail lights | TT vents | Bilstein B14 | RNS-E 2010 | AMI | AKS Tuning custom CAI | Titanium BBS VZs | NQS BBK | WALK | Autotech RARB | Bluemotion aero | Blueflame TBE | Autotech HPFP | MY11 Wing Mirrors | Bluetooth | S3 Intercooler
PLANS
: Stage 2+
3
17
All Things Mk5
Members Rides
Jump to:
=> Members Rides
