Author Topic: Can emergency brake or hazard light flash be enable via VCDS?  (Read 5232 times)
Offline vag12
As above really can this be done to the mk5? Oh and bdw am new to this forum so hello and my name is John
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Can emergency brake or hazard light flash be enable via VCDS?
« Reply #1 on: July 15, 2012, 03:07:15 pm »
welcome
i think it depends on which Central Electrics Control Module (CECM - otherwise called "central electrics board") you have
PLANS: Stage 2+
« Reply #2 on: July 15, 2012, 03:11:35 pm »
If its on your convenience module (I think this feature is found on most of the modules) then its a very quick job to enable
With vcds :happy2:
Welcome along
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: July 15, 2012, 03:21:58 pm »
it is in the CECM
available on most, easy to enable
Cluster and Key coding
Location Great Yarmouth
Offline vag12
« Reply #4 on: July 15, 2012, 03:31:39 pm »
Cheers guys, Seems like a very helpful forum, I take it if the option is available on VCDS then it can be enabled?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Offline ConeKiller
« Reply #6 on: July 15, 2012, 05:53:03 pm »
Eddie-NL set it up on mine, has activated a couple of times under harsh braking, good thing to have!
Offline vag12
« Reply #7 on: July 15, 2012, 06:55:55 pm »
Does the Hazard light get activated or just the brake light?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #8 on: July 15, 2012, 07:35:52 pm »
you have your foot on the brake - brake light on
Hazard lights flash
« Reply #9 on: July 15, 2012, 08:35:57 pm »
Is this feature available on a midline equipped Mk5 GTI, does anyone know please?
It's a very good safety feature.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #10 on: July 15, 2012, 08:37:36 pm »
you can get flashing brake lights, but only on higher end CECMs
i really want to do this mod, but i can't find the right CECM for my car and they're about £250 from a dealer (for my Audi A3 anyway)
PLANS: Stage 2+
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #11 on: July 15, 2012, 08:44:01 pm »
should be on yours Robin, get someone with Vag-com to have a look
only the very early cars 2004 and very early 2005 didn't have the option
« Reply #12 on: July 15, 2012, 09:04:39 pm »
Thanks, Eddie  :happy2:
Mine is a 06-build (post July 2005). Crikey! She's 7 years old very very soon.
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #13 on: July 15, 2012, 09:17:40 pm »
Will you splash on a Mk7?
'07 Red manual
« Reply #14 on: July 15, 2012, 10:03:19 pm »
....No.
I lost a six-figure sum of money last year and simply can't afford to. Besides which, I'm still in love with my Mk5  :happy2:
