Author Topic: Help tyre pressure ?  (Read 40624 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=87njo285hnrnschvrqbl0hbm0o&/topic,19740.0.html
Re: Help tyre pressure ?
« Reply #15 on: July 21, 2012, 07:25:38 pm »
I use 38psi all round on my 18" Goodyear Assymetrics...
....Is that based on any info from Goodyear?
Is more car weight and tyre size specific Robin, rather than brand to brand variation.
Offline jamma
« Reply #16 on: July 21, 2012, 08:39:15 pm »
Thanks all .37 psi then
Offline bacillus
  • -Receive: 451
« Reply #17 on: July 21, 2012, 09:00:26 pm »
I just played around with the pressure and find that value suited the car without any wear problems.
Offline david25
  • -Given: 19
« Reply #18 on: July 22, 2012, 07:34:02 pm »
^ The label on my fuel flap on my 06-build spec Mk5 GTI.
Thanks Robin, was your car supplied with 17 or 18inch wheels? Because the Ed30 sticker below is different?
Offline david25
  • -Given: 19
Offline sanj
  • -Given: 17
« Reply #20 on: July 22, 2012, 07:39:15 pm »
All Edition30 car's came with 18" alloy's from factory. :smiley:
Offline david25
  • -Given: 19
« Reply #21 on: July 22, 2012, 07:48:35 pm »
Sure, I was just asking Robin what size wheels his normal GTI came with.
Offline mkviken
« Reply #22 on: July 22, 2012, 08:19:32 pm »
my mk6 is 38psi which is very high compared to everything else
its strange as our focus has 31f 33r and its heavier car
the ford handbook also has different pressures for 16/17/18" tyres and if its a diesel or not of if you exceed 100mph setting too.
wonder why vw didn't do this. 38psi for a mk6 across the board is a very general setting.
h4rdy
« Reply #23 on: July 22, 2012, 08:37:32 pm »
Robin did you not see my thread venting my disappointment in the Good years?
35psi for Goodyear F1 Assy2 :confused:
....Why does this confuse you? - I ask because I run the GY F1 Asymm2's.
35 psi = 2.4 bar
Offline Black9
  • -Given: 35
« Reply #24 on: July 22, 2012, 08:40:06 pm »
Was running my PS3s at 32, noticed some wear on outer walls. Up to 35psi now. Hopefully that should help, does anyone know the official pressure for 18" PS3s?
Offline bacillus
  • -Receive: 451
« Reply #25 on: July 22, 2012, 08:41:26 pm »
Robin's car originally came with 17" rims.
  • -Given: 380
  • -Receive: 442
« Reply #26 on: July 22, 2012, 09:12:47 pm »
....That's correct [Sorry I wasn't available to answer]
  • -Given: 380
  • -Receive: 442
« Reply #27 on: July 22, 2012, 09:14:18 pm »
....I don't remember if I did - Sorry!  :ashamed: - Gotta link?
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #28 on: July 22, 2012, 09:26:02 pm »
I run either 36 or 37 psi, when a1 first fitted them they was 38.
Stupid question but if the 18's are meant to be 37 why does my local dealer always drop them to 34 once it's been in??
Offline Frenzy
  • -Receive: 29
« Reply #29 on: July 22, 2012, 10:09:54 pm »
i run 35 or 36 psi on 18" vreds. they run and handle great so i'm not changing this. Also IIRC fuel cap on mine says 2.4 bar
