April 14, 2025, 08:37:32 pm
All Things Mk5
Mk5 General Area
Mfsw
Topic: Mfsw (Read 1418 times)
nadlad
Won't Shut up.
-Given: 1
-Receive: 7
GT Sport 08 140PS
Mfsw
July 27, 2012, 11:33:49 pm »
Got myself a mfsw mk5 wheel what else will i need apart from highline to get it working do I need to change the steering control module cars a 08 gt sport. Cheers
Touran Build Thread
skard
Just look at my post count
-Given: 5
-Receive: 245
My Ride:
Re: Mfsw
Reply #1 on:
July 27, 2012, 11:37:35 pm »
Control module, MFSW airbag loom and VCDS coding
nadlad
Won't Shut up.
-Given: 1
-Receive: 7
GT Sport 08 140PS
Re: Mfsw
Reply #2 on:
July 28, 2012, 12:05:19 am »
What part number control module do I need
Touran Build Thread
jason_rmh
Won't Shut up.
-Given: 69
-Receive: 81
Re: Re: Mfsw
Reply #3 on:
July 28, 2012, 09:30:57 am »
Depends on your existing slip ring.
Type 1 or type 2. The only real way to know is to physically check.
However, knowing the part no of your existing steerIng control module will help give an indication.
Jas
VCDS (Preston, Lancashire)
JoeDarKa
-Given: 57
-Receive: 74
Re: Mfsw
Reply #4 on:
July 28, 2012, 09:35:01 am »
You should have the correct slip ring as my 58 reg GT sport had the correct one. Changed the steering controller though, got it off Eddie on here!
GT Sport - Reflex Silver 2.0 TDI
My Build
jason_rmh
Won't Shut up.
-Given: 69
-Receive: 81
Re: Re: Mfsw
Reply #5 on:
July 28, 2012, 09:45:12 am »
True, I didn't need to change mine either.
If you get the part number of your existing Steering wheel control module from the vcds scan then check here on the Ross tech page which should tell you which slip ring is fitted with that module.
http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions
You can also use that page to check your existing slip ring is compatible with your new module.
When fitting my mfsw I fitted a CH module which gives the option of using a mk6 steering wheel also if you fancy a change later on.
Jas
nadlad
Won't Shut up.
-Given: 1
-Receive: 7
GT Sport 08 140PS
Re: Mfsw
Reply #6 on:
July 28, 2012, 11:23:31 am »
Oh brilliant I actually have the ch module for my mk6 wheel under my table which I was going to fit at some point but I got a mk5 mfsw cheap so I just thought a try that out and see how it goes but didn't fancy buying another module.
I'll find out what part number mine is do I just go into steering and it should tell me part number cheers
Touran Build Thread
Eddie-NL
Trader - 2014
-Given: 0
-Receive: 298
My Ride:
Re: Mfsw
Reply #7 on:
July 28, 2012, 01:35:16 pm »
use the CH one you have
just remember to use the lower number coding for a mk5 wheel
Genuine VCDS VAG-COM HEX-USB + Genuine Vag Commander + Genuine VAG Tacho + Genuine VAG CAN PRO + RNS Manager for Video in Motion and New Pin Code for RNS510
Cluster and Key coding
Location Great Yarmouth
All Things Mk5
Mk5 General Area
Mfsw
Jump to:
=> Mk5 General Area
