Author Topic: Hurdy's Golf .:R.  (Read 760360 times)
Re: Hurdy's Golf .:R ...Loba turbo time....
« Reply #1815 on: October 01, 2013, 12:32:54 pm »
Update....
Teaser pic :wink:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ltpcjro154agtjive91tc4dt88&/topic,19740.0.html
« Reply #1816 on: October 01, 2013, 01:07:33 pm »
Whats happening now? Upgraded drive shaft? Or new DP?
Offline vRSAlex
  • -Receive: 253
« Reply #1817 on: October 01, 2013, 01:08:36 pm »
Intake air temp sensor is in the inlet manifold above the throttle body.  Spacer plate still injects before it.  :happy2:
Loving the new 90mm downpipe.
Follow AKS tuning on Facebook
Offline H17YD_L
« Reply #1818 on: October 01, 2013, 02:03:09 pm »
I'm considering WMI you have this kit don't you?
http://www.methanol-injection.co.uk/product_info.php?cPath=21&products_id=28
Did you fit it yourself or get stallers to? Where did you put the activation sensor and where do you inject? I have the BSH/Revo throttle pipe so there are 2 ports I could use there? Or is there somewhere better?
Sorry for all the questions, but I know your the man for meth :)
Statllers did the install, but if you have the time and skill it isn't a hard kit to fit, just takes time.
The boost tap for the toggle switch was done off the end of the intake manifold where the cap off is for my PCV blank and I have a Revo boost tap at that point to plumb into.
The toggle switch is easily accessible in the small glovebox just below the right hand side of the steering column on my R.
I inject on the lower of the two ports in my BSH throttle pipe. The lower one is better as it passes the sensor to detect the cooling given by the evaporation of the spray and gives it time to mix thoroughly before going into the manifold.
Some people recommend having the throttle spacer and inject at that point, but I don't believe that you'd get as good a mixture and hence less benefit.  :happy2:
Thanks for the info!!
Did you buy your kit from devilsown themselves or a dealer?
S3 Sportback S-Tronic GONE... MK7 R on order
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #1819 on: October 01, 2013, 02:07:15 pm »
My guess is also the 90mm DP, any before and after EGT's?  :happy2:
Over the top mod list ;o)
Offline dan930
  • -Receive: 56
« Reply #1820 on: October 01, 2013, 02:34:11 pm »
Custom 3" exhaust john
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
« Reply #1821 on: October 01, 2013, 04:45:26 pm »
Ah, must have been thinking of the oxy sensor!
« Reply #1822 on: October 01, 2013, 04:46:33 pm »
Steve already had a kit on stock at the time, so it would have been rude to refuse. :wink:
« Reply #1823 on: October 01, 2013, 04:54:30 pm »
Yeah Jake, Alex and Dan are all right. Here's another pic, but what is it?
« Reply #1824 on: October 01, 2013, 05:16:42 pm »
BCS?
Offline H17YD_L
« Reply #1825 on: October 01, 2013, 05:31:34 pm »
+1 on the BCS
Offline vRSAlex
  • -Receive: 253
« Reply #1826 on: October 01, 2013, 05:43:27 pm »
Its got a cnc bracket onto the subframe by the looks of it,, so I'm confused to what it is. Bcs cats are 5" and that looks 4".
You mean the map sensor john  :happy2:
« Reply #1827 on: October 01, 2013, 05:45:43 pm »
Decat... with a box to make it look 'legal'?
Either that or a swap in swap out system.
Looks nice whatever it is.
« Reply #1828 on: October 01, 2013, 07:11:35 pm »
Hahaa, well done Rich. It is a resonated box made to resemble the cat. Should easily be able to swap in a cat onto it as the system is now being done with full 304 investment cast flanges.
Hedge... Definitely not BCS :smiley:
Offline jonnym
  • -Given: 40
« Reply #1829 on: October 01, 2013, 07:26:11 pm »
Cheeky boy! :grin: You could always get a guaranteed pass!  :innocent:
