Author Topic: Mac and internet problem.  (Read 1354 times)
« on: August 23, 2012, 05:09:23 pm »
I haz a Macintosh,  came home today  and it would not load any internet pages. Emails still working fine.  :chicken: So did the usual and rang India complaining about BT. Turns out my connection is working fine, so while waiting to be transferred to some one trained on Mac i thought i would switch it off ( Japenes restart ) and it was working again before the guy came back on line.
Just did something else for an hour, went to go back on tinternet and the same has happened. Obviously working now after another off and back on, but there is some sort of fault.
Normally runs like a Rolls Royce, and i dont even know were to look to try and trace the problem. Looked in system prefs and all there is for tinternet is auto connected which showed connected.  :fighting2:
Anyone any ideas.  :drinking:
Offline edd666999
  • -Receive: 89
Re: Mac and internet problem.
« Reply #1 on: August 23, 2012, 05:13:09 pm »
When you cant connect, check the lights on your router see if they are normal
Try a different browser.
Do you have any security installed on your mac?
Are you wirelessly connected to the router or eithernet cable?
« Reply #2 on: August 23, 2012, 05:20:19 pm »
When you cant connect, check the lights on your router see if they are normal  All lights ok on hub.
Do you have any security installed on your mac?  No.
Are you wirelessly connected to the router or eithernet cable? tried both, emails still working so guessing it is not the wireless connection.
« Reply #3 on: August 23, 2012, 05:30:36 pm »
Sorry Mr Cat but the temptation is too much.  :P
 :innocent:
Offline galaxie500
  • -Given: 38
  • 56 plate 5 door in Black Pearl Metallic
« Reply #4 on: August 23, 2012, 05:33:56 pm »
Pull the power from the router for 5 minutes; so much traffic going through it needs a kickstart.
Get Little Snitch - programme that shows how much data is being sent to and from your machine.  Its frightening how much stuff is being sent and from uyour computer!  Little Snitch allows you to block certain companies without resorting to firewall changes.
Thank goodness, Mac's still don't crash nearly as often as the other machines out there.......Mr Hedge!
« Reply #5 on: August 23, 2012, 05:34:31 pm »
I would rather stick wasps up my ass hedge....  :innocent:
« Reply #6 on: August 23, 2012, 05:37:46 pm »
Ooh I'd like to see that Rich.  :laugh:
« Reply #7 on: August 23, 2012, 05:38:54 pm »
I bet you would...    :scared:
« Reply #8 on: August 23, 2012, 05:39:24 pm »
The router is working fine, i have reset and switched it off, this was confirmed by switching the mac off and it worked when i put it back on.
My Mac has only ever crashed once so i am certainly not complaining about it. My suspicions are safari, but i dont know how to check it for faults though. Does it store logs or glitches.  :happy2:
Offline bacillus
  • -Receive: 451
« Reply #9 on: August 23, 2012, 05:44:03 pm »
I suspect BT are having "DNS server not responding issues" atm...
« Reply #10 on: August 23, 2012, 05:45:12 pm »
So why were my emails coming through fine.  :popcornsoda:
« Reply #11 on: August 23, 2012, 06:03:18 pm »
BT email runs on Yahoo which may explain why.  :smiley:
Offline edd666999
  • -Receive: 89
« Reply #12 on: August 23, 2012, 06:20:33 pm »
under system preferences and network then dns
add the following dns servers in:
208.67.222.222
208.67.220.220
