Author Topic: Rattles!  (Read 6736 times)
Offline john87
  • -Receive: 53
Rattles!
« on: August 29, 2012, 09:52:51 am »
Has anyone else experienced an intermittent but frustrating rattle coming from the rear of the car?
With the gloriously potholed roads we have in this country, coupled with the Monza 2's, I've noticed this rattle more and more recently, it sounds like something in the armrest compartment or an empty bottle in a rear cup holder when I go over potholes and even upon engine start/stop..however there's nothing in said cup holders or armrest compartment  :confused:
I doubt very much that I'm going to get to the bottom of this, but I'll seek some comfort in knowing I'm not alone on this. Or am I?  :laugh:
Offline TIGER-UPPERCUT
Re: Rattles!
« Reply #1 on: August 29, 2012, 11:14:17 am »
I get a rattle coming from the rear passenger side.  Looks like its coming from the boot area, thought it was parcel shelf but thats in solid.  It seems to be coming from the plastic behind the rear lights...
2006 GTI - KWv1 - Poly Fronts - K&N Panel Filter - RTech Stage 1
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: Rattles!
« Reply #2 on: August 29, 2012, 11:19:17 am »
There is metal clips that hold the inside plastic to the boot lid sometimes the plastic can brake & the metal clips bounce around in there...
Hope that helps you out  :happy2:
Silver is the way !
  • -Given: 380
  • -Receive: 442
Re: Rattles!
« Reply #3 on: August 29, 2012, 11:21:05 am »
So, is it definitely a rattle and not a clunk or squeak? And definitely from inside the car? - Sound travels so can be tricky to source.
Small stone caught in a brake shield?
Screw worked loose somewhere in the interior trim?
Rear seats bedded properly?
Re: Rattles!
« Reply #4 on: August 29, 2012, 11:33:34 am »
You need to drive around with someone in the back listening for the noise.
  • -Given: 380
  • -Receive: 442
Re: Rattles!
« Reply #5 on: August 29, 2012, 11:39:43 am »
.... :signLOL:
I wish I could quickly find that vid of someone travelling in the boot in an attempt to locate an undesirable sound. I think it's from a movie.
Would you mind getting into my boot, Jas?
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: Rattles!
« Reply #6 on: August 29, 2012, 11:43:42 am »
 :signLOL:
Funny that... Oh Hello Officer Just checking for sounds there really annoying the driver
Silver is the way !
Offline JMP
Re: Rattles!
« Reply #7 on: August 29, 2012, 11:49:35 am »
If you have a subwoofer, feed sine waves (approx 20Hz-100Hz) throught it with a moderate to high volume when car is standing still. Go up the frequency one by one or use a sweep. You will most likely hit the correct frequency for the rattle. Then just put it in an repeat and go find & fix it.
Offline john87
  • -Receive: 53
Re: Rattles!
« Reply #8 on: August 29, 2012, 12:13:14 pm »
Thanks for the replies folks  :happy2: I have come to the conclusion that it's something loose either behind a panel or under the seat, its definitely not the seat bench at it's tight down and the noise is still there when there's people in the back... and the fact that I can hear the rattle when I turn off the engine suggests that its something unrelated to the cars' movement (suspension etc).
When she goes in for precat removal next week, I'll have a look underneath and see if it's anything to do with the milltek
  • -Given: 380
  • -Receive: 442
Re: Rattles!
« Reply #9 on: August 29, 2012, 12:17:25 pm »
....I don't quite understand how the rattle can be heard when the engine is off and there is no car movement. A rattle is a sound which is only created by movement,
Wasps nest? Dirty big blow fly?
Offline john87
  • -Receive: 53
Re: Rattles!
« Reply #10 on: August 29, 2012, 12:25:01 pm »
Haha  :grin: what I meant was that the sound can be heard briefly when the engine is shut off, i.e. the engine shutting down causes just enough vibration to cause said rattle...and it really is quite a smooth engine so it must be something bloody sensitive!
Offline Sonic6103
Re: Rattles!
« Reply #11 on: August 29, 2012, 12:26:57 pm »
I might be wrong but just with the start up and switching off of the engine makes me think it could be the exhaust vibrating on something or maybe even a heat shield too. I'm not sure if it's a similar noise to this but maybe worth a check
Good luck with it and I hope you find it soon too!
Karl
Re: Rattles!
« Reply #12 on: August 29, 2012, 01:14:36 pm »
Thanks for that will have a look.
Offline gigolo456
Re: Rattles!
« Reply #13 on: August 29, 2012, 01:36:10 pm »
I had a rattle recently that sounded like the boot wasn't shut properly, but only ever happened when the car was bang up to temperature, never when cold or just warming up! I convinced myself it was to do with my recently installed TBE, and sure enough when the exhaust was moved a bit, well made longer in fact, said rattle/banging now gone (touch wood)!!
Re: Rattles!
« Reply #14 on: August 29, 2012, 02:10:10 pm »
I think there are a few things I'd rather not do in my life. Getting into the boots of you and Hedge is one of them.
