Author Topic: CEL - EGR VALVE  (Read 6230 times)
Offline Kingabzyy
CEL - EGR VALVE
« on: September 05, 2012, 12:48:08 pm »
Ok guys, i have a mkv golf 1.9 tdi se 06 plate. i have a check engline light on and went to Rich yesterday to get it scanned, the following fault came up
001025 - EGR System
               P0401 - 000 - Insufficient Flow
             Freeze Frame:
                    Fault Status: 01110000
                    Fault Priority: 0
                    Fault Frequency: 3
                    Mileage: 92622 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:09:36
             Freeze Frame:
                    RPM: 1512 /min
                    Speed: 25.0 km/h
                    Load: 12.5 %
                    Duty Cycle: 14.6 %
                    Duty Cycle: 100.2 %
                    Mass Air / Rev.: 240.0 mg/str
                    Mass Air / Rev.: 515.0 mg/str
i have my car booked in tommorow to CLEAN the EGR valve at VW dealer at a quoted price of £160. recieved a call from them saying we cannot guarantee that the engine light will go off with this procedure or it might go off and come back on in say a week. he said replacing the EGR valve definelty cure the problem but quoted £560.
anyone shed some light on this, thanks in advance
Offline AndyS
Re: CEL - EGR VALVE
« Reply #1 on: September 05, 2012, 12:53:27 pm »
EGR valves get very dirty on deisel cars, a lot more if you drive short distances.
Cleaning the crap out of the EGR value will normally remove the fault, unless you EGR value is sticking or worn.
Get it cleaned, don't pay out that money.......
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: CEL - EGR VALVE
« Reply #2 on: September 05, 2012, 01:19:56 pm »
Get the EGR delete kit from Darkside and get your tuner to erase the fault that comes after the removal
http://www.darksidedevelopments.co.uk/products/darkside-1-9-8v-pd105-2-0-16v-tdi-pd-ppd-and-cr-egr-delete-race-pipe.html
Done the trick for me  :happy2:
Over the top mod list ;o)
Offline Matto
  • -Receive: 116
Re: CEL - EGR VALVE
« Reply #3 on: September 05, 2012, 01:45:25 pm »
+1 for the Darkside delete. I have done exactly the same. No more filthy egr valve  :fighting:
« Last Edit: September 05, 2012, 01:47:16 pm by Matto »
Offline apples12
Re: CEL - EGR VALVE
« Reply #4 on: September 05, 2012, 02:32:15 pm »
Lol at that price!
Remove the egr yourself and give it a good clean, it should fix it, for that sort of money you can get a remap which includes a rolling road and an egr delete from someone like r-tech to eliminate the problem reoccurring!
MK6 GT TDI  - CW - LUX pack
GONE
MkV Golf 1.9TDI Sport in DBP, 160,000 miles and climbing!
Retrofits by me:GT front end,OEM bixenons with auto-levelling/washers, Valeo LED Rears, MFSW + Highline SWCM, Cruise Control, 30byte Highline CECM, Highline clocks, Rain/Light Sensor, Auto-dimming Rear view Mirror, RNS-510 LED (Ver H; SW: 4020), Fiscon Basic Bluetooth, MDI + Aux, Armrest, Reverse Camera LOW, TPMS..what next...
Offline TrickGTI
Re: CEL - EGR VALVE
« Reply #5 on: September 05, 2012, 06:43:11 pm »
I'd go for the EGR delete to they are nothing but problems! plus it's a fit and forget about it mod so no future problems!!
2006 Tornado red GTI
Offline Kingabzyy
Re: CEL - EGR VALVE
« Reply #6 on: September 05, 2012, 08:49:44 pm »
Thanks for reply guys. I'm a dummy at that kind of stuff so i won't know how to do it. Anyone in the London area that can fit the EGR delete kit?
Offline Kingabzyy
Re: CEL - EGR VALVE
« Reply #7 on: September 05, 2012, 11:48:00 pm »
Looks like Volkswagen it is then :sad1:
Re: CEL - EGR VALVE
« Reply #8 on: September 05, 2012, 11:49:18 pm »
Id offer.. but ive never done it before so I wouldnt want to mess it up.
Offline Kingabzyy
Re: CEL - EGR VALVE
« Reply #9 on: September 06, 2012, 12:08:42 am »
Appreciate it rich. But like u said no messing up
Re: CEL - EGR VALVE
« Reply #10 on: September 06, 2012, 12:13:01 am »
Message alex on here.. and see how much it would be to fit the EGR delete..... VRSAlex
http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=1981
Offline Matto
  • -Receive: 116
Re: CEL - EGR VALVE
« Reply #11 on: September 06, 2012, 06:38:08 am »
Rich...you would be very unlucky to mess is up. It's only 3 bolts that hold it on.
Start be removing the clip that holds the hose in then pull that out. Then undo the 3 bolts that hold the anti-shudder valve to the egr, one bolt is longer from memory and holds both the asv and egr to the manifold. Disconnect the plug and remove asv. You should now be left with 2 screws holding the egr on plus 2 on the connecting metal pipe on the right hand side. Disconnect the plug and there you go.
I just used carb cleaner to clean it. I'd suggest wearing rubber gloves if you do it otherwise your hands will be black for weeks.
Have a look in my members ride for pics of what the asv and egr look like when removed  :happy2:
« Last Edit: September 06, 2012, 09:12:38 am by Matto »
  • -Given: 243
  • -Receive: 154
Re: CEL - EGR VALVE
« Reply #12 on: September 06, 2012, 07:41:51 am »
Mortygttdi also has some photos in his build tread of the egr delete he did on his car.
