Author Topic: removing the orange reflectors from rear lights  (Read 8583 times)
Offline jedi-knight83
  • -Receive: 41
« on: September 10, 2012, 05:04:34 pm »
Has anyone done this?
The orange looks a bit naff especially now i've put a clear fog reflector in (red bulb so still passed MOT)
But trying to strip down my outer lights and you cant get to the orange reflector without splitting the lens off the front which I dont want to do to my new ED30 lights....
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: removing the orange reflectors from rear lights
« Reply #1 on: September 10, 2012, 05:11:34 pm »
I'd say no go... and also need reflectors for mot.
Diesel Daily Hack.
  • -Receive: 41
« Reply #2 on: September 10, 2012, 05:20:23 pm »
there is a clear reflector there. it just has an orange filter behind it. I can see through the hole that the orange filter clips off separately... its just getting to it without breaking the light.
Oh and I've found orange flashing bulbs so that base is also covered.
  • -Receive: 41
« Reply #3 on: September 10, 2012, 05:21:16 pm »
didnt people split these units to fit those valeo LED bits like on the golf plus?
Offline Jonny
  • G7R Owner
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,45008.0.html
« Reply #4 on: September 10, 2012, 05:25:48 pm »
Just slightly off topic, how hard was it to switch the fog reflector and replace with a reverse reflector? Looks a neat mod if it's not time consuming :)
  • -Receive: 41
« Reply #5 on: September 10, 2012, 05:27:15 pm »
That bit comes out easy and is easy to get to when you unscrew the bulb holder. And the red bulb doesnt show through so it doesn't look stupid but its still legal.
Offline vRSAlex
  • -Receive: 253
« Reply #6 on: September 10, 2012, 06:48:07 pm »
I used to remove the orange inserts from the mk3 ibiza tail lights.  Just used a soldering iron to make a cross in the plastic then snap the quarters off and pull them out.
Follow AKS tuning on Facebook
  • -Receive: 41
« Reply #7 on: September 10, 2012, 07:15:58 pm »
Oh I see what you mean...
doesnt that risk damaging the clear reflector behind it..
and also if then the source of orange bulbs dries up then your left a bit high and dry.
« Reply #8 on: September 10, 2012, 07:38:44 pm »
....Not that I'm aware of. Folks buy the whole Valeo units instead - They are 'OEM'.
Offline vRSAlex
  • -Receive: 253
« Reply #9 on: September 10, 2012, 07:40:14 pm »
Always a risk, just take care while doing it.
Not sure we would ever run out of orange or silvertech bulbs.  Every other car needs an orange bulb.  :P
  • -Receive: 41
« Reply #10 on: September 10, 2012, 07:46:03 pm »
You've never seen the mk5 rear indicator bulb then.
I've found a guy that has some LED bulbs that flash amber and are also canbus safe.... but he had to get them specially made... and having looked around the net I can believe him.
  • -Receive: 41
« Reply #11 on: September 10, 2012, 07:58:00 pm »
really want to try this now... just nervous on my ed30 lights.
« Reply #12 on: September 10, 2012, 07:59:47 pm »
Because the Mk5 GTI rear indicators are so naff (poor visibility) is partly why I swopped them for Valeo LED units:  http://www.mk5golfgti.co.uk/forum/index.php/topic,4469.0.html
Offline daboy3000
  • MKV GT TDi
« Reply #13 on: September 11, 2012, 10:53:06 am »
I did the same with my Boxter, they call it an amberectomy!  Soildering iron into the cluster, then some bottle nosed pliers.  I was sh*tty myself when doing it but it came out fine, you just need some silvertec bulbs to finish it off.
  • -Receive: 41
« Reply #14 on: September 11, 2012, 11:29:33 am »
Understand your reasoning for doing it but I'm not a huge fan of the look and the centre LEDs dont match the outer ones perfectly and it would bug the hell out of me.
