Author Topic: Beige Mk1 golf 1.8t 20v The Rebuild!  (Read 58031 times)
Offline higher1
Re: Beige Mk1 golf 1.8t 20v
« Reply #30 on: November 15, 2012, 05:32:58 pm »
My new wheels arrived today fresh from the polishers
Ah-exclusive custom ultra low H&R Coilovers 110mm, ITG induction kit, 18" super RS's, USA rear bumper, USA front grille with smooth number plate surround,recaro bucket seats. now sold !
mk1 golf 1.8 20v turbo
Offline Dan648v
  • -Given: 28
« Reply #31 on: November 15, 2012, 06:15:54 pm »
Nice! You staying as is? Or fancying a coloured centre?
Offline higher1
« Reply #32 on: November 15, 2012, 08:48:07 pm »
They are staying polished I've just had them done that way
« Reply #33 on: November 15, 2012, 11:53:02 pm »
Stunning as usual Simon.  :notworthy:
The engine bay is gonna be as epic as those wheels  :drool:
Offline higher1
« Reply #34 on: November 16, 2012, 07:39:02 pm »
Thanks mate pretty sure it's gonna have a bare metal respray now as I want it spot on
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #35 on: November 16, 2012, 08:55:44 pm »
Looks fantastic  :drool:
Offline Snoopy
  • -Given: 31
« Reply #36 on: November 18, 2012, 08:32:52 pm »
Nice build. Is it still a pain to find new original panels it was when i did mine.
Offline higher1
« Reply #37 on: November 18, 2012, 09:06:28 pm »
It's getting hard to find genuine parts loads of repo stuff about but you can't beat genuine bits
Offline higher1
« Reply #38 on: December 14, 2012, 04:30:41 pm »
so to update ive cut out a little bit of rust in the tailgate and formed a panel to weld in place keeping it with all the original seams etc
the black part is the new panel
and it welded and ground back
etch primed
started to take the nsr quater panel back to bare metal as i know they suffer from rust around the rear windows
took the scuttle panel back to bare metal as its showed signs of rust im going to replace it at a later date
nsr quarter back to bare metal
started on the ns door and along the drip rail
test fit of the genuine wing
Offline higher1
« Reply #39 on: December 14, 2012, 04:49:05 pm »
cut the scuttle panel out
removing the last bits along the windscreen edge
old and new
popped the bonnet on to measure
spotting the new one in place
all welded in place
then work stopped for a weekend as i went with my dad to collect his new project a 1969 mk2 lotus cortina it needs a full resto but its a good base
back on the golf i cut a bit of corrosion out of the bulk head and made a plate to weld in
welded a repair section into the corner of the scuttle
Offline higher1
« Reply #40 on: December 14, 2012, 04:56:04 pm »
built a wheel up to test fit i cant run a very wide wheel on the front as it has huge 4 pot calipers and need a spacer to clear them
new drivers door skin arrived so i ground the old one off
test fit of the new one
then spotted it in a couple of places before a trial fit on the car
popped it on with the wing for gapping etc and finished spot welding the door skin on
now the scuttle panel was for a LHD its all that was available so i welded the wiper holes up
also welded the aerial hole up on the wing
Offline higher1
« Reply #41 on: December 14, 2012, 05:05:05 pm »
the new wing needed the arch lip cutting down to help reduce any tyre rub
before standard large return edge
after edge cut back
the bonnet is a complete mess the previous paint prep was bad, the paint just flakes off with a chisel
as you can see the top was just a build up of paint and high build
a close up to show you how thick it was it totally ruined the defining lnes of the bonnet etc
out come the sander
im not running rear arch spats so i welded the holes up
still going on the bonnet lol
started to take the ns door back to
back to bare metal
the bonnet was a nightmare so out came the paint stripper
and it back to bare metal
« Last Edit: December 14, 2012, 05:22:11 pm by higher1 »
Offline higher1
« Reply #42 on: December 14, 2012, 05:13:55 pm »
stripped the ns wing back to bare metal
and the same with the tailgate
that brings us upto date, so at last it was time to etch prime all the bare metal although theres a long way to go its a turning point for me as at last things arent being stripped or taken off
i would like to say im not a bodyshop guy or a sprayer im a mechanic and i work on motor caravans, this is the 1st time ive ever really done body work even though ive modified cars for many years.
panels ready for etch primer i borrowed some panel stands from a neighbour
made good use of the 2 poster lift and hung the rest from it
and primed
Offline higher1
« Reply #43 on: December 14, 2012, 05:16:05 pm »
and today a quick build up of the car to check panel gaps etc alls good im very pleased with the car so far
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #44 on: December 14, 2012, 08:23:18 pm »
Looks great, proper job!
