Author Topic: to increase mpg what is the normal engine warm up time ?  (Read 19887 times)
scottm72
« on: October 08, 2012, 06:09:25 pm »
just out of interest to increase the starting mpg what is the normal engine warm up time from cold, i usually dont allow any warm up time tbh but would be interested if anyone knew
Offline Banham
  • GTI MK6
Re: to increase mpg what is the normal engine warm up time ?
« Reply #1 on: October 08, 2012, 06:17:38 pm »
If it is cold i always let my engine warm up. I never drive off until my revs have dropped. But not to sure when it starts to save mpg but the first recording i get on the display is around 10mpg
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #2 on: October 08, 2012, 06:21:38 pm »
Your KO3/4 won't thank you for this.
'07 Red manual
« Reply #3 on: October 08, 2012, 06:23:39 pm »
When my engine (Mk5 GTI K03) first starts up the revs are just over ~1000. I wait for the revs to drop below 1000rpm and for the engine sound to settle before I engage gear. This can take as long as a couple of minutes.
It's kinder to the DSG gearbox and allows fluids to circulate and automatic processes to happen.
I'm not aware of mpg being effected by this at all and wouldn't expect it to be.
Obviously it's also good practice not to use higher revs until at least the temp gauge is centred - Unfortunately the GTI doesn't have an OEM oil temperature gauge.
scottm72
« Reply #4 on: October 08, 2012, 06:27:13 pm »
dude us noobs out there dont know ehat a K03/4 is, sorry but can you dumb that down  :happy2:
« Reply #5 on: October 08, 2012, 06:29:01 pm »
....K03 is the turbocharger which is standard on the Mk5 GTI and K04 is the turbo which is standard (aka OEM) on the Ed30 (Edition 30 Mk5 GTI).  :happy2:
Actually, it's the engine as much as the turbo that won't thank you for cold starts without any warm up or revs settling.
« Last Edit: October 08, 2012, 06:31:29 pm by RedRobin »
scottm72
« Reply #6 on: October 08, 2012, 06:30:16 pm »
thanks for that rr, im thinking if i drive straight off then the mpg will be worse but yes i guess it would be good practice in general to wait until the rpms reduce on the idle before engaging gear, fluids circulating etc,,,,, btw the temp gauge in my old mk4 took about 10 minutes to centre lol
scottm72
« Reply #7 on: October 08, 2012, 06:32:46 pm »
right got that now, so i will have a K03 ( mk5 gti ) so i guess to be nice wait for the rpm to calm down before driving  :happy2:
« Reply #8 on: October 08, 2012, 06:36:59 pm »
When I lived in London a friend of mine had a Ferrari (well, several) and he used to spend literally about 4 minutes warming up the engine. Older technology but the same principles apply. It's completely logical: Going from zero revs and cold fluid temperatures to thousands of revs per minute is not kind to any engine. But most people don't realise or care about this.
I think it's more important than the mpg.
scottm72
« Reply #9 on: October 08, 2012, 06:38:39 pm »
yes i agree, thanks for that rr, will do in future
« Reply #10 on: October 08, 2012, 07:33:27 pm »
I tend to drive off almost instantly but I keep the revs to below 2000rpm. IIRC the car's components are designed in the knowledge that they will warm up at different rates and hence keeping the engine at idle for minutes at a time means some parts of a car will heat up more quickly than others and at a different rate to planned.
Offline Sonic6103
« Reply #11 on: October 08, 2012, 07:42:01 pm »
I do the same as Stealthwolf. I only have it running for around 10 seconds before setting off sometimes but I keep the revs very low, around 2,000 or less. I just make sure I always let it cool down, sometimes just for 10-20 seconds but if I do this then I'll have already pretty much been running on tick over for the last mile or so n not in boost.
Some people will obviously say that's wrong but it's just the way I do it and I've never had any problems in all the turbo cars I've had :)
« Reply #12 on: October 08, 2012, 07:46:12 pm »
+1 for no boost in the last mile or so of a journey. I normally wait a few seconds before switching off but if I've not been able to drive without boost in the previous mile, I keep the car idling for a little longer.
Offline andrewparker
  • -Given: 32
  • -Receive: 78
« Reply #13 on: October 08, 2012, 07:51:57 pm »
I'd love the luxury of even 1 minute to warm an engine first thing in the morning! :laugh:
« Reply #14 on: October 08, 2012, 07:59:17 pm »
BUY A DIESEL  :signLOL:
