April 06, 2025, 07:23:03 pm
All Things Mk5
Performance Modifications
Which uprated DV?
Topic: Which uprated DV? (Read 6627 times)
tony_danza
Just look at my post count
-Given: 3
-Receive: 112
The voice of objective reason, but mine's best.
Which uprated DV?
June 17, 2009, 03:42:14 pm »
I've had the version G off today and it's looking pretty shagged already, gone all baggy - no holes, but I can feel it isn't working as well as when new.
So, time to upgrade me thinks. What's the other options aside from a Forge one?
Sideways yo!
Hurdy
-Given: 52
-Receive: 137
Re: Which uprated DV?
Reply #1 on:
June 17, 2009, 04:21:24 pm »
You could either go for a Forge, a Forge or even a Forge DV...then again you may just be better with a Forge DV
Don't resist, just come over to the Forge side young Danza
tony_danza
-Given: 3
-Receive: 112
Reply #2 on:
June 17, 2009, 04:28:25 pm »
I believe there may also be an EVOMS one....
Sideways yo!
GTIjames
Won't Shut up.
-Given: 6
-Receive: 6
Reply #3 on:
June 17, 2009, 04:36:42 pm »
go Revision D - new piston type from VW, had it on since january no probs
cheaper than forge no maintenance required which you do with forge and according to vag logs in the US holds boost longer than the forge
I paid around £40
tony_danza
-Given: 3
-Receive: 112
Reply #4 on:
June 17, 2009, 04:44:29 pm »
Is that what stealers are putting on as warranty swap outs these days?... wonder just HOW much I can take the p*** when it's in tomorrow??
Sideways yo!
GTIjames
Won't Shut up.
-Given: 6
-Receive: 6
Reply #5 on:
June 17, 2009, 04:48:22 pm »
they'll will probably put a 'g'one on if you ask for it to be replaced, as technically the 'd' is meant for the new tsi but as I said had it on since jan and no probs
according to my boost guage i hold 23 psi right up to 7krpm!
john_o
-Given: 136
-Receive: 108
Reply #6 on:
June 17, 2009, 04:56:41 pm »
Quote from: GTIjames on June 17, 2009, 04:48:22 pm
whooosh
now thats holding boost , mine drops to 15psi or less at 7k!
maybe I should change mine anyway just to be sure
Red ED35 5dr DSG
BLOG
BUILD
SteveS
-Given: 14
-Receive: 10
Reply #7 on:
June 19, 2009, 02:46:39 pm »
yes, cant say i would recommend the forge with my issues...
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs | VWR Shortshift | SuperPro Bushes | Recaro Seats
Mark_GTIV
Always Involved
-Given: 13
-Receive: 23
Reply #8 on:
June 19, 2009, 03:11:23 pm »
I've just ordered the TSI (rev D) VAG OEM DV [part number 06H 145 710 D] from my dealer. I'm removing my Forge DV - I find it a bit slow witted compared to the OEM one and even with the uprated spring it starts to bleed off boost at around 5K RPM.
OEM Piston DV all the way
jt1
Always Involved
-Given: 8
-Receive: 5
Reply #9 on:
June 19, 2009, 03:27:23 pm »
Just picked up my oem d version today, will be fitting in the morn
nick-barnes07
Always Involved
-Given: 0
-Receive: 4
Reply #10 on:
June 19, 2009, 11:37:59 pm »
go forge, i have a forge on mine with the spacer and it sounds just right, not to chavvy or whooshy, just a nice ttttsssssshhhhh,
sambo
Always Involved
-Given: 3
-Receive: 1
Reply #11 on:
June 24, 2009, 09:24:30 pm »
Does that revision D TSI DV fir both axx aand bwa engine codes?
Mine's an early one, looking for a solid replacement.
Cheers, Sam
Golfster S
Always Involved
-Given: 2
-Receive: 0
Reply #12 on:
June 24, 2009, 10:24:38 pm »
I have the Forge fitted as well, havn't really noticed much difference in the whoosh factor, then again, I had the Turbo back Non Res Milltek fitted at the same time.......
Reflex Silver GTI Edition 30
tony_danza
-Given: 3
-Receive: 112
Reply #13 on:
June 25, 2009, 09:12:36 am »
I ended up ordering a D-type, whether I live to regret that remains to be seen...
Sideways yo!
Jaywoo-GTI
-Given: 38
-Receive: 34
Reply #14 on:
June 25, 2009, 09:23:40 am »
D types fit early AXX engines as i have on eon mine, And the can also be modified to fit a forge spacer valve.
All Things Mk5
Which uprated DV?
