April 02, 2025, 06:42:56 am
All Things Mk5
Mk5 General Area
Help! Lowering problem
Topic: Help! Lowering problem (Read 980 times)
Sam89
Always Involved
-Given: 3
-Receive: 1
October 28, 2012, 08:49:40 am »
I know this may sound daft but how do i get the strut out of the hub on the front??? It moves a few mm but just will not come out? Anyone?
Baz300
Won't Shut up.
-Given: 9
-Receive: 26
Re: Help! Lowering problem
Reply #1 on:
October 28, 2012, 08:55:40 am »
I unbolted the bottom ball joint, track rod end and pulled the driveshaft out of the hub to get enough room to remove the strut
Put plenty of grease in to make refitting and realigning the strut easier.
And when you tighten the driveshaft bolt make sure it is done with the weight off the wheels
Sam89
Always Involved
-Given: 3
-Receive: 1
Reply #2 on:
October 28, 2012, 08:59:29 am »
How did you manage to pull it out of the hub tho (the strut) ?
gazbutS3
Just look at my post count
-Given: 52
-Receive: 55
Reply #3 on:
October 28, 2012, 09:03:58 am »
Quote from: Sam89 on October 28, 2012, 08:59:29 am
assuming you ahve the bolt removed
, you need to open the joint in the hub a little, there are special tools for this or you can just use a pry-bar. A good spray with WD40 will help too
Sam89
Always Involved
-Given: 3
-Receive: 1
Reply #4 on:
October 28, 2012, 09:06:56 am »
Yes the bolt is removed, i tried prying it apart but its pretty tight, like i said it moves a few mm and seems loose tgen it just goes no further! Ill spray more wd and try that
Baz300
Won't Shut up.
-Given: 9
-Receive: 26
Reply #5 on:
October 28, 2012, 09:12:04 am »
I used an old Allen key socket and ground half of it down on a bench grinder.
Inserted it into the gap on the hub behind the strut and gave it a quarter turn opening up the gap.
And as above I had to disconnect the hub as there is not enough room to take the strut out otherwise
Sam89
Always Involved
-Given: 3
-Receive: 1
Reply #6 on:
October 28, 2012, 09:14:40 am »
Cheers guys ill go see if i can crCk it now
Neiltdi
Always Involved
-Given: 14
-Receive: 8
Full Hex+CAN
Reply #7 on:
October 28, 2012, 09:29:43 am »
May sound daft but i pulled the whole leg/strut/hub out as one (it means taking caliper off and the disk and guard) but then just beat the hub with a copper mallet worked pretty well
Full Hex+CAN in Hampshire.
biffobear
Always Involved
-Given: 2
-Receive: 12
Reply #8 on:
October 28, 2012, 08:56:18 pm »
best to remove the caliper so you dont strain the brake hose then using a length of scaffolding about 6ft , insert between the chassis and the hub and lever down till the strut is parted from the hub, easy.
All Things Mk5
Mk5 General Area
