Author Topic: Help! Lowering problem  (Read 976 times)
Offline Sam89
« on: October 28, 2012, 08:49:40 am »
I know this may sound daft but how do i get the strut out of the hub on the front??? It moves a few mm but just will not come out? Anyone?
Offline Baz300
Re: Help! Lowering problem
« Reply #1 on: October 28, 2012, 08:55:40 am »
I unbolted the bottom ball joint, track rod end and pulled the driveshaft out of the hub to get enough room to remove the strut
Put plenty of grease in to make refitting and realigning the strut easier.
And when you tighten the driveshaft bolt make sure it is done with the weight off the wheels
Offline Sam89
« Reply #2 on: October 28, 2012, 08:59:29 am »
How did you manage to pull it out of the hub tho (the strut) ?
Offline gazbutS3
« Reply #3 on: October 28, 2012, 09:03:58 am »
assuming you ahve the bolt removed :wink:, you need to open the joint in the hub a little, there are special tools for this or you can just use a pry-bar. A good spray with WD40 will help too :happy2:
Offline Sam89
« Reply #4 on: October 28, 2012, 09:06:56 am »
Yes the bolt is removed, i tried prying it apart but its pretty tight, like i said it moves a few mm and seems loose tgen it just goes no further! Ill spray more wd and try that
Offline Baz300
« Reply #5 on: October 28, 2012, 09:12:04 am »
I used an old Allen key socket and ground half of it down on a bench grinder.
Inserted it into the gap on the hub behind the strut and gave it a quarter turn opening up the gap.
And as above I had to disconnect the hub as there is not enough room to take the strut out otherwise
Offline Sam89
« Reply #6 on: October 28, 2012, 09:14:40 am »
Cheers guys ill go see if i can crCk it now  :happy2:
Offline Neiltdi
  • Full Hex+CAN
« Reply #7 on: October 28, 2012, 09:29:43 am »
May sound daft but i pulled the whole leg/strut/hub out as one (it means taking caliper off and the disk and guard) but then just beat the hub with a copper mallet worked pretty well
Full Hex+CAN in Hampshire.
Offline biffobear
« Reply #8 on: October 28, 2012, 08:56:18 pm »
best to remove the caliper so  you dont strain the brake hose then using a length of scaffolding about 6ft , insert between the chassis  and the hub and lever down till the strut is parted from the hub, easy.
