Author Topic: Red mood led lights  (Read 3805 times)
Offline A1dan2.0tdisport
Red mood led lights
« on: November 07, 2012, 10:29:25 pm »
Does anyone know where to get the red led's from the front light unit?
Wanting to install some in the rear lighting unit.
Thanks anyone for a reply
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
Re: Red mood led lights
« Reply #1 on: November 08, 2012, 03:43:43 pm »
ebay!
« Reply #2 on: November 28, 2012, 10:16:16 pm »
Been looking but carnt find the mini LEDs for the mood lighting.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Cluster and Key coding
Location Great Yarmouth
« Reply #4 on: November 28, 2012, 10:26:39 pm »
Cheers Eddie, that's brill mate but I was hoping to find the led's so I could try a little DIY job :),
Probably be much simpler to just buy that and plug and play.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: November 28, 2012, 10:30:38 pm »
any leds will do
« Reply #6 on: November 28, 2012, 10:36:39 pm »
Ye probably just might not be a exact colour or brightness match. :(
Offline Matto
  • -Receive: 116
« Reply #7 on: November 29, 2012, 10:33:35 am »
I've always fancied this little mod after seeing your Ed. The only bit that put me off was dropping the headlining to run the feed wire down to the rear. Is it much of a job?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #8 on: November 29, 2012, 10:37:36 am »
you don't do that
drop the front light
take the back one out
feed the wire from the front to the rear, wire into the front light (grey & brown wires) refit front light
Plug rear light back in, job done (took about an hour to do)
Offline Matto
  • -Receive: 116
« Reply #9 on: November 29, 2012, 11:01:40 am »
Ah cool. I was just under the impression you was unable to feed the wire between the lining and roof do to isulation etc. Not too bad a job at all then  :happy2:
« Reply #10 on: November 29, 2012, 11:07:36 am »
Did you drill holes and fit the LEDs in the rears then Eddie?
Then just take the supply from the front LEDs?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #11 on: November 29, 2012, 11:21:32 am »
Yes and yes
Offline paulw123
  • -Receive: 47
