Author Topic: Reducing the rotational unsprung mass - wheel weight reduction benefits  (Read 7608 times)
I've been searching the web and there are several features etc on the benefits of reducing wheel weight, namely better performance and better handling.
Calculations vary wildly from 1kg saving on the wheel = 1.5kg from the body of the car all the way to 1kg saving on the wheel = 10kg saving on the body of the car.
I found a more accurate spreadsheet that calculated savings by different formulas that basically meant for my 5kg saving per wheel (20kg total) it was the equivalent of saving 84kg from the body of the car. This calculation took into account diameter of the wheel, mass (at both the outer limit+tyre), width etc and seems to comply with some other calculations that equate 1kg saving at the wheel is the equivalent of saving 4-4.5kg on the body of the car for acceleration purposes.
Other additional benefits are that reducing the wheel weight will put less stress on the suspension parts and as a result a better ride and less "crashyness". Also the wheels have a "gyroscopic effect" on the car's handling and so the lower the weight and the smaller the average diameter of the rotating mass, the easier it is to turn the wheels and as an effect the handling appears crisper.
Has anyone got any more sources of information that could be helpful?
Offline gazon69
Re: Reducing the rotational unsprung mass - wheel weight reduction benefits
« Reply #1 on: November 12, 2012, 12:05:11 pm »
Good thing i got my superleggeras then john  :wink:
« Reply #2 on: November 12, 2012, 12:41:57 pm »
Yup, my new alloys should be here tomorrow :smiley:
Yours probably save around 5kg a corner over stock too :happy2:
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #3 on: November 12, 2012, 12:46:04 pm »
I was always made aware 1 kg on the outside = 5-8kg on the inside... You seem to be on the right track...
Silver is the way !
« Reply #4 on: November 12, 2012, 05:39:04 pm »
Well, when I had a passenger in the car at the pod my fastest time was 12.787. The fastest time without was 12.615, so if the calculations are correct I should be looking at around 0.15-0.17 off the 1/4 mile time with just lighter wheels :surprised:
Offline gazbutS3
« Reply #5 on: November 12, 2012, 05:42:16 pm »
so the same/similar must apply to weight savings on brakes too, although its not all rotating mass :happy2:
« Reply #6 on: November 12, 2012, 05:49:08 pm »
True... the weight of an R32 disc is the same as a wheel and tyre..... (... well... nearly  :signLOL: )
Offline gazbutS3
« Reply #7 on: November 12, 2012, 05:51:54 pm »
can't be much in it :laugh:
« Reply #8 on: November 12, 2012, 06:54:43 pm »
A solid rotating disc will have a greater effect than the weight it saves, but due to the bulk of it's mass being nearer the centre of rotation it doesn't have as much overall effect as alloys which have the bulk of their weight at the rim. It is still all on the unsprung mass though and will make for better handling too. :smiley:
My god! I must have learned something to remember that :laugh:
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #9 on: November 12, 2012, 07:16:25 pm »
Indeed
Peripheral weighting is a trick of gyroscope engineers, before laser ring gyros and Solid state accelerometers ....avionics engineers used to peripherally weight the small gyroscopes inside aircraft instruments to make them more gyroscopic for less weight...the technical term when a gyro is spinning is rigidity...
Precession is the phenomenomenon of any force acting on a rigid gyro at 90 degrees to the force applied, Caliper position is designed in to help,or hinder the ability of a wheel and tyre to turn in when braking.
Remember when you span a cycle wheel on your finger tip and it didn't fall off, remember trying to push it from the top say 12 oclock and it just spinning left and right.
Thing is looking at things in a complicated manner...simply remember unsprung weight is the scourge of performance and handling.
« Reply #10 on: November 12, 2012, 07:21:17 pm »
Indeed
I fully understand precession but how is caliper position relevant... front or back of the disc, what implications does it have?
« Last Edit: November 12, 2012, 07:37:23 pm by richwig83 »
Offline gazbutS3
« Reply #11 on: November 12, 2012, 07:29:48 pm »
Indeed
ah your bringing back my college days, the 3 finger rule, or was that something else  :laugh:
« Reply #12 on: November 12, 2012, 07:36:48 pm »
LOL....left hand rule.... feels like someone else is working it out!  :signLOL:
  • Trader - 2014
  • -Receive: 130
« Reply #13 on: November 12, 2012, 07:53:33 pm »
Indeed
If you look at some Porsches Rich they have the Caliper at 10.30 o clock instead of 3 o'clock or 9, it's a handling tuning thing. It's more prevalent on bikes where caliper position is pretty much always on the vertical or near the forks
Offline gazbutS3
« Reply #14 on: November 12, 2012, 08:11:46 pm »
thats the rascal, the 3 finger rule was in the student union lol
