Author Topic: Lets talk Stage 2 Edition 35.......WITH PICTURES  (Read 14568 times)
  • -Given: 380
  • -Receive: 442
Re: Lets talk Stage 2 Edition 35........
« Reply #45 on: January 09, 2013, 10:44:30 pm »
It wasn't so long ago, Oli, that I recall you saying that you never ever mod your cars  :laugh:
Offline bacillus
  • -Receive: 451
« Reply #46 on: January 09, 2013, 11:12:39 pm »
Anyone have any recommendations where to ge them if I need them?
You could support a fellow forum member by getting them from here http://www.gnjmotorsport.com/products/H%26R-Trak%252b-3mm-%286mm-Per-Axle%29-Hubcentric-Wheel-Spacers-%26-Bolts-VAG-PCD-5%7B47%7D112%2C-Centre-Bore-57.1%2C-Bolt-Thread-14x1.5.html
Apart from there get ones by H&R or Forge.  :smiley:
Offline wigit
  • -Given: 129
  • -Receive: 42
« Reply #47 on: January 10, 2013, 02:59:43 pm »
will be interesting how you get on Oli with the clearance on the 19s, the 18s are a pinta for clearance and probably up there with the pescaras, my 18s need spaces to clear the AP 4 pot set up so still deciding which way to go  :fighting:
Offline Oli
  • -Given: 19
« Reply #48 on: January 10, 2013, 03:03:57 pm »
Just about to test fit the brakes, I think they will need 5 or 8mm spacers.
I might also be getting some H & R coilovers and go stage 2+.............
Offline andrewparker
  • -Given: 32
  • -Receive: 78
« Reply #49 on: January 10, 2013, 04:30:14 pm »
Oil, why on earth doesn't this thread have any photos of your car?! Come on man, get some uploaded!
Offline wigit
  • -Given: 129
  • -Receive: 42
« Reply #50 on: January 10, 2013, 04:46:29 pm »
don't forget the rear diffuser in gloss black Oli  :innocent:
« Last Edit: January 10, 2013, 05:07:48 pm by wigit »
  • -Given: 32
  • -Receive: 78
« Reply #51 on: January 10, 2013, 04:59:16 pm »
Have you got a build thread Wigit?
Offline wigit
  • -Given: 129
  • -Receive: 42
« Reply #52 on: January 10, 2013, 05:15:11 pm »
not got round to doing an update on this as been way too busy and not got time to sort out some decent pics but in essence its now running
Revo Stage 2, full set of Revo engine mounts, Miiltek TBE, eibach arbs and Bisltein B16s PSS10s and gloss diffuser, GTI badge removed and 35 on rump
its in for first service soon and then intake, 4/6 pots (proving a mare) and slap the red S3 rears on I have in garage
http://www.mk5golfgti.co.uk/forum/index.php/topic,45294.0.html
Offline Oli
  • -Given: 19
« Reply #53 on: January 10, 2013, 06:58:03 pm »
Being done soon  :happy2:
Offline Oli
  • -Given: 19
« Reply #54 on: January 10, 2013, 06:58:57 pm »
Haha, I know, slack as.  Ill get some up on completion  :happy2:
Offline chungster
« Reply #55 on: January 10, 2013, 08:34:10 pm »
How did the brake fitting go Oli??
Offline Oli
  • -Given: 19
« Reply #56 on: January 10, 2013, 08:42:28 pm »
Spacers on order, Ive ordered 5mm and 8mm, I think the 8mm will be best to give a little clearance.
Exhaust is nearly on, will be finished in the morning. Then stage 2 coding will be on moday am, and brakes hopefully fitted in the afternoon  :happy2:
Offline chungster
« Reply #57 on: January 10, 2013, 08:43:48 pm »
Don't forget the longer wheel bolts too in that case!  :happy2:
Offline Oli
  • -Given: 19
« Reply #58 on: January 10, 2013, 09:30:05 pm »
all sorted :happy2:
Offline Oli
  • -Given: 19
« Reply #59 on: January 11, 2013, 11:05:18 pm »
Sorry no pictures yet, but I will get some up after the brakes are done.
The exhuast is now fitted.  I went for the race system resonated, and It sounds great.  The standard system on the Ed35 sounded really good already and I didnt want to loose that, and Milltek have done it perfectly, the DSG pharps are slighlty louder, and maybe the exhaust slightly louder overall, but its very oem, which I like.  What I have noticed is the increase in torque, and the engine feels looser - more freer reving, as Ive noticed on previous Milltek systems.  One thing that is very good, is the slight hesitation that I had after each gearchange under full throttle, after the stage 1 map was put on, has now gone totally  :smiley:
Roll on monday, when Im off to Vanworx to get the stage 2 coding, and pick up the wheel spacers, to fit the brakes.  I think it will be a good all round package then.
 :smiley:
