Author Topic: Removing the Charcoal Canister (Part of the EVAP)  (Read 19812 times)
Re: Removing the Charcoal Canister (Part of the EVAP)
« Reply #15 on: November 19, 2012, 10:46:16 am »
Red  :innocent:
« Reply #16 on: November 19, 2012, 10:52:14 am »
What is the benefit of going this?
« Reply #17 on: November 19, 2012, 10:54:28 am »
Room for a decent size catch can rather than the red bull sized BSH can.  Plus cleaner, tidier bay.
May be more reasons.
  • -Given: 380
  • -Receive: 442
« Reply #18 on: November 19, 2012, 11:13:13 am »
....Is that the only reason? - It doesn't seem worth the hassle, especially as a revision to a remap is tricky to get.
My solution was to sell my BSH and get a Forge Catch Tank which modifies the screenwash tank filler:
^ BEFORE - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -  ^ AFTER
« Last Edit: November 19, 2012, 11:18:10 am by RedRobin »
  • -Given: 380
  • -Receive: 442
« Reply #19 on: November 19, 2012, 11:21:38 am »
If you are that bothered by the appearance of the charcoal canister you can always dress it up with a cover.
The aluminium one by Forge costs ~£90 though. But if Show is your thing.................
Offline Cupra R
  • -Given: 18
Offline vRSAlex
  • -Receive: 253
« Reply #21 on: November 19, 2012, 06:24:45 pm »
Forge tank is too small for the TFSi imo.  Fills up with moisture too fast.  I'm running a larger Forge item now and it takes far far longer to require an empty.
Follow AKS tuning on Facebook
Offline Statller-Stevo
« Reply #22 on: November 19, 2012, 07:06:51 pm »
I suppose if it really meant that much to you, you could always lengthen the pipe work to the canister and hide it under the O/S wheel arch liner plenty of room under there on the Golfs not sure about the Octavia though. would be an easy job with no MIL problems
Offline vRSAlex
  • -Receive: 253
« Reply #23 on: November 19, 2012, 07:09:07 pm »
Similar to how the US cars are as they have the canister at the back near the spare wheel well.  Easy enough to map out though.
  • -Given: 380
  • -Receive: 442
« Reply #24 on: November 19, 2012, 07:16:48 pm »
....Too small? I only have to empty mine about every 6-8 weeks or so, depending on time of year.
So is this larger Forge item a new product? On release yet?
Offline vRSAlex
  • -Receive: 253
« Reply #25 on: November 19, 2012, 08:13:33 pm »
It's one I've pieced together.  Will get a pic.  In winter mine needs emptying every other week.
« Reply #26 on: November 19, 2012, 08:51:38 pm »
Suppose it depends on milage not time.... i would be emptying mine every other day.  :signLOL:
Offline murph81
  • -Given: 17
« Reply #27 on: November 20, 2013, 10:50:32 pm »
Has anyone got any photos of the pipe and solenoid valve removed and blocked off?
Offline vRSAlex
  • -Receive: 253
« Reply #28 on: November 20, 2013, 11:00:40 pm »
I will try and get some of mine tomorrow. Mine is all mapped out now.
« Reply #29 on: December 19, 2013, 07:52:05 pm »
No more MiL Alex?
