Author Topic: Forge twintercooler MPG  (Read 1684 times)
Offline raptor_tom22
« on: November 24, 2012, 10:09:41 am »
Has any one else with a forge twintercooler noticed a drop in MPG? I had mine for about a week before the fuel consumption dropped by about 4 MPG down to about 30 MPG which makes me feel i have another problem.
I do have a judder issue every know and again and have changed to a forge dump valve and a catch tank but still that problem is there. when it does happen it won't rev above 3000rpm either with no lights flashing on the dash and diagnostics not showing any faults? Thoughts would be much appreciated.
Offline bacillus
  • -Receive: 451
Re: Forge twintercooler MPG
« Reply #1 on: November 24, 2012, 01:32:27 pm »
Theoretically you should see a slight rise of mpg with the twintercooler fitted.
Do bear in mind that it's getting colder now and that decreases your mpg.
Offline greygti
« Reply #2 on: November 26, 2012, 05:24:49 pm »
30 mpg from a 2.0l turbo'd car ,i would not worry about that in the slightest mate personally i think that's good !
Offline VWPalmer
« Reply #3 on: November 27, 2012, 10:33:34 pm »
I only got 28mpg in mine when it was standard  :signLOL:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=v1l272f8lf2g8179ff6oe96mul&/topic,19740.0.html
« Reply #4 on: November 27, 2012, 10:45:05 pm »
Can you elaborate?
Offline jimojameso
« Reply #5 on: November 28, 2012, 08:51:47 am »
Can you elaborate?
Car takes longer to warm up so mpg decreases. Once its up to to temp it will be better on fuel as the air is colder but until then will be worse  :happy2:
2010 Audi TT RS - Sepang Blue - 420BHP, 600NM
Offline graeme
« Reply #6 on: November 28, 2012, 08:54:08 am »
Do you have a new downpipe on the car ?
« Reply #7 on: December 12, 2012, 04:28:41 pm »
Sorry for the late answers, I've not been able to get to a computer for a while. I'm still running a standard exhaust an down pipe. I was thinking about the pre cat modification to see if that may help with the mpg aswell as helping the car breath :)
I think it must be down to the cold weather aswell, don't think it's got above freezing today
