Author Topic: Which is correct ?  (Read 1576 times)
Offline big.el
Which is correct ?
« on: November 25, 2012, 01:40:34 pm »
Looking for some alloys for my golf and I was just wondering which of these is correct
Just a bit confused  :stupid:
Offline sub39h
  • -Given: 189
  • -Receive: 84
Re: Which is correct ?
« Reply #1 on: November 25, 2012, 01:48:51 pm »
well what Golf do you have? Mk4 - 5x100, Mk5 - 5x112, Mk6 - 5x112 as it says in the pictures you've posted. centre bore will be 57.1 for all 3, but if it's wider than this it doesn't matter much, you just need some spigots.
PLANS: Stage 2+
Offline big.el
« Reply #2 on: November 25, 2012, 02:00:53 pm »
Mk5 as per bottom picture  :happy2:
Sorry I meant the offset lol there saying different things.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #3 on: November 25, 2012, 02:15:04 pm »
then it depends on wheel width and what you want the car to look like
PLANS: Stage 2+
Offline big.el
« Reply #4 on: November 25, 2012, 02:27:56 pm »
I mean i want to know the offset boundries on the standard set up. Not every wheel with a 5x112 fitment will fit will it ?
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #5 on: November 25, 2012, 02:45:55 pm »
no but the width of the wheel affects the offset choice. so for example, not all wheels with an offset of 42 will fit either
the standard set up is 7.5J ET51. this is the same as 8J ET57, 8.5J ET63 and 9J ET69 in terms of where the wheel face will end up in relation to the arch.
have a play on here. it'll probably answer your question, even tho i'm still not sure exactly what it is you're asking:
http://www.1010tires.com/WheelOffsetCalculator.asp
« Last Edit: November 25, 2012, 02:53:20 pm by sub39h »
PLANS: Stage 2+
