Author Topic: Can some one help with misfiring / recommend someone to help  (Read 1337 times)
Offline jamiep91
« on: November 30, 2012, 09:00:55 am »
Since buying my mk5 gti I've had a misfire so took it to jabbasport earlier in the week and was told it was something in the map causing it so had a remap.. Which made it better but didnt solve it and when I collected it they told me this buy didnt seem interested I'm fixing it ? And charged me top dolla for the remap so just a bit p****d off ATM can anyone help
They did tell me the misfire was In cylinder 2 so don't know where to go from here.
Thanks in advance for any help  :smiley:
Offline jamiep91
Re: Can some one help with misfiring / recommend someone to help
« Reply #1 on: November 30, 2012, 09:11:35 am »
Also stalls when I slow down fast and pull away , spark plugs have been changed and could swapped around I believe
Offline bacillus
  • -Receive: 451
« Reply #2 on: November 30, 2012, 10:55:06 am »
Misfire is usually down to problems with spark plugs, coil pack or injector.
If they've already changed plugs and did the "coil pack shuffle" without resolution makes me suspect an injector issue.
Offline jamiep91
« Reply #3 on: November 30, 2012, 12:06:14 pm »
Would this cause it to stall when slowing down ?
« Reply #4 on: November 30, 2012, 11:50:54 pm »
Yes.
« Reply #5 on: November 30, 2012, 11:56:38 pm »
so they mapped the car but it  still had a misfire charged you for it and showed you the door :stupid:
Offline jamiep91
« Reply #6 on: December 01, 2012, 04:41:53 am »
Yeh pretty much, I couldn't be bothered to argue at the time because I needed my car but ill be ringing up to say the problem is still there
