Author Topic: Can someone explain revo switch  (Read 2821 times)
Offline Scrubadub
  • Soon to be "bagged"
« on: December 02, 2012, 09:17:31 pm »
Off for a stage 2 remap on Wednesday at JKM on my ko3 gti.
I'm slightly concerned about the battery disconnect worry with settings changing.
What switch can I buy to be able to change settings back if battery disconnected? Will an sps3 work?
Fun bags
Offline maxload
  • -Given: 41
  • -Receive: 29
  • Edition30 - No.1819
Re: Re: Can someone explain revo switch
« Reply #1 on: December 03, 2012, 01:52:15 pm »
The Sps switch doesn't contain the settings the ecu does. By connecting the sps switch to your laptop, with the revo software you can then alter the boost, timing and fueling levels to your needs. Someone may correct me, but by disconnecting the battery it just reverts the car back to stock, the revo map is still on the ecu so it would just be a case of using the sps switch to alter the settings back as they were.
Sent from my GT-S5830 using Tapatalk 2
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ajb8dr8720tnh84nr58o4ifl40&/topic,19740.0.html
« Reply #2 on: December 03, 2012, 01:56:21 pm »
Not strictly true... the SPS does contain the numeric settings i.e B9 T6 F8 or B6 T6 F9. The map on the car contains all the information to allow these numeric values to alter the map. This is why it works in 5 seconds as its not having to write the whole map (a la Bluefin)
Offline edd666999
  • -Receive: 89
« Reply #3 on: December 03, 2012, 02:03:46 pm »
The Ecu contains the map.
When you disconnect the battery your settings revert to t0 b1 f0
A sps unit allows to to change these back what they should be at.
Offline Scrubadub
« Reply #4 on: December 03, 2012, 09:32:18 pm »
Got ya. I rand JKM and they sold the old sps switches won't work with there new software and that I will need a "switch plus" which is the newer version.
Was only asking as can pick up the older 1s on eBay cheap
Fun bags
  • -Given: 380
  • -Receive: 442
« Reply #5 on: December 03, 2012, 09:41:21 pm »
....So if the old SPS switches don't work on the new Revo software you are getting, why would you want to buy an older switch?
Offline edd666999
  • -Receive: 89
« Reply #6 on: December 03, 2012, 11:24:20 pm »
older switch does work, you just need the older software for your pc.
