Author Topic: More DV questions.........  (Read 2512 times)
Offline swgti
  • -Given: 28
« on: December 03, 2012, 07:56:35 am »
Apologies I know this is done to death on here but a lot of the info is very confusing so here goes, just a few questions I have before I go and get one as I want to be clear as to what type I want...........
1. Rev D is the older type and is a piston version?
2. Rev G is the latest used on the Mk6 and the likes and is a diaphram?
3. Other than personal preference they are both as good as each other and can cope with re-mapping?, oh and the Rev G makes a better noise? :happy2:
4. Are both types still available from VW or do you have to go elsewhere for the older D type?
Offline andrewparker
  • -Given: 32
  • -Receive: 78
Re: More DV questions.........
« Reply #1 on: December 03, 2012, 08:06:31 am »
Yes on all accounts :happy2:
Offline Mk5 GTian
  • -Receive: 37
« Reply #2 on: December 03, 2012, 08:09:03 am »
It would seem it's a case of swings and roundabouts. JKM use the Rev D, so that was good enough for me in my decision making.
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #3 on: December 03, 2012, 08:38:52 am »
1. The Rev D is newer than the G.
2. The Rev D is the one found on the Mk6.
3. Apparently the G holds boost better. Speak to your tuner because personal preference does play a role too it seems
4. They're both available from VW
PLANS: Stage 2+
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #4 on: December 03, 2012, 01:10:08 pm »
Now that is right  :happy2:
The "D" is a plastic on plastic seal so wont hold boost as well as a totally sealed diaphragm (like the "G").
Both work fine, although i've tried both and have to say, the "G" feels a little more responsive at lower revs and makes a bit more of a "hiss" when I let off the throttle.
Nick @ R-Tech smoke tested a "D" and posted a picture showing it leaking, which sounds about right as plastic on plastic is never going to be an air tight seal, which is why I went back to the "G"
If a "D" does leak, it wont be as noticable as a rubber Diaphragm splitting as it will only be a small amount down the side of the piston, however it means your turbo will be working harder to sustain the boost your map is requesting.
« Last Edit: December 03, 2012, 01:13:16 pm by GrayMK5GTI »
Offline swgti
  • -Given: 28
« Reply #5 on: December 03, 2012, 01:14:11 pm »
Thanks folks, looks like I'll opt for the Rev G when I get round to getting one. :driver:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #6 on: December 03, 2012, 01:17:07 pm »
I would say rev d on K03 cos of heat from turbo making diaphram brittle and splitting, rev g on K04 cars...
JKM said mine was holding it's boost up to redline when it went stage 2+, and that has a G ;)
Diesel Daily Hack.
« Reply #7 on: December 03, 2012, 01:20:11 pm »
Plastic on metal...  :happy2:
Offline Rachael
« Reply #8 on: December 03, 2012, 02:08:59 pm »
Have been through countless number of these posts and I'm still confused!
So to confirm, on a k03 gti, it's better to have the g? I have a 2006 gti, so will I have the d?
Ahhh so confused  :scared:
« Reply #9 on: December 03, 2012, 02:10:15 pm »
ON a normal GTI you are better to have the plastic piston version as the DV is exposed to heat from the turbo.
Offline swgti
  • -Given: 28
« Reply #10 on: December 03, 2012, 02:16:30 pm »
And the piston is the D yes?
This is the first time I've come across people mentioning the heat issues on a K03 up until now I was swayed towards the G simply because its supposed to boost better.
Anyone got the part No for the D. I've got the G No.
Offline Carpy25
« Reply #11 on: December 03, 2012, 03:04:38 pm »
part number I used was 06H 145 710 D but please check this first
Rob
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #12 on: December 03, 2012, 04:20:17 pm »
Ah it's just as bad  :grin:
« Reply #13 on: December 03, 2012, 04:22:38 pm »
  • -Receive: 427
« Reply #14 on: December 03, 2012, 05:31:28 pm »
This!  :happy2:
G for what's its worth.
