Author Topic: Part numbers correct?  (Read 1395 times)
Offline exodus_ste
« on: December 10, 2012, 02:06:00 pm »
Just about to throw an order at my local stealers:
Latest revision DV: 06H 145 710 D
Charcoal canister: 1KO 201 797 AE
Cam follower: 06D 109 309 C
Are these the right numbers for an 07 Ed30?
Also, is there a latest revision PCV setup from VW?
Steve
Offline chrisr763
  • -Receive: 62
Re: Part numbers correct?
« Reply #1 on: December 10, 2012, 02:09:24 pm »
Your best bet might be to google each part number..? Sorry to be no help  :smiley:
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #2 on: December 10, 2012, 02:22:07 pm »
not sure on the part numbers, but i do know that not all engines accept the latest version of the PCV and you sometimes have to go for a slightly older version
PLANS: Stage 2+
« Reply #3 on: December 10, 2012, 02:26:00 pm »
Yes, seem spot on...
Cam Follower  - 06D 109 309 C
Revision D Divertor Valve    -  06H 145 710 D
Charcoal Canister  -   1K0 201 797 AE
And the PCV latest Revsion is the N. s the one to have on an Edition 30. Mine Eddy and many others are better with this one.
PCV   -   06F 129 101 N
and you may need a new orange rubber seal for the PCV as well.
Seal   -  06F 103 483 E
« Last Edit: December 10, 2012, 02:27:53 pm by MC71 »
Offline 56OctyVRS
  • -Receive: 72
« Reply #4 on: December 10, 2012, 02:32:56 pm »
The dealer will tell you the G revision is the correct dv for your engine. Plenty of topics on D vs G on here. Ive had both and found the G to feel better with power delivery.
« Reply #5 on: December 10, 2012, 02:40:03 pm »
^^^^ I'm fast asleep, blindly answering the post for a Revision D part number even when i have changed my own DV from D to G on my ED30. doh  :stupid:
@EXODUS_STE.  ignore the D revision part number and go with the above G revision recommendation.
06H 145 710 G
« Last Edit: December 10, 2012, 02:50:21 pm by MC71 »
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #6 on: December 10, 2012, 02:46:04 pm »
I'd suggest going with the "P" revision PCV, no need to change the rear breather valve then  :happy2:
Offline exodus_ste
« Reply #7 on: December 10, 2012, 03:36:06 pm »
sh*t..... just ordered a 'D' DV  :sad1:
shall get onto them asap!
Also got told that the charcoal canister isnt available as a VW part, Audi only apparantly...  :confused:
So if ive ordered a revision 'N' PCV, i need something else aswell? Ive ordered the orange rubber seal 06F 103 483 E
Thanks for the help so far guys  :happy2:
Offline exodus_ste
« Reply #8 on: December 10, 2012, 03:56:00 pm »
Just called them again... The 06H 145 710 G isnt recognised by the dealer  :confused:
Now i am very confused! Don't know why but i seem to recall reading somewhere about not being able to get a certain revision?
Steve
« Reply #9 on: December 10, 2012, 05:19:46 pm »
That is the correct part number for the DV and its available as far as I know for around £35 from any VAG dealer or TPS (try another dealer) Not sure about the rear breather on the PCV as the garage changed mine, hopefully someone who knows for sure will help you out.
Offline Kalpsn2000
  • -Receive: 56
« Reply #10 on: December 10, 2012, 05:28:51 pm »
The correct part number is 06F 145 710 G. I bought it a couple of weeks ago for £38.84 inc VAT :happy2:
Offline exodus_ste
« Reply #11 on: December 10, 2012, 07:23:06 pm »
That'll be the reason then.....
Thanks mate  :happy2:
« Reply #12 on: December 10, 2012, 08:19:55 pm »
^^^^ I'll get my coat  :sad1:
Sorry buddy. Really not with it today.
Offline 56OctyVRS
  • -Receive: 72
« Reply #13 on: December 10, 2012, 11:02:28 pm »
The correct pcv valve is the N revision for the Ed 30s as they werent fitted with a rear check valve like the later TFSi's
« Last Edit: December 10, 2012, 11:14:50 pm by 56OctyVRS »
