Author Topic: Disc change  (Read 2119 times)
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Disc change
« on: December 17, 2012, 11:35:16 am »
I need to change out my front discs, but not the pads (they're fine).
Can I take just off the caliper carrier with the two 21mm bolts - will the calipers & carrier come off together? Or must I remove the calipers first and then the carrier?
'07 Red manual
Offline biffobear
Re: Disc change
« Reply #1 on: December 17, 2012, 07:00:39 pm »
calipers bolt directly to hub, remove 2 bolts, little screw holding disc on usually siezed on.
Offline andybon
Re: Disc change
« Reply #2 on: December 17, 2012, 07:04:44 pm »
And your old pads will be bedded to your old disks, So any deep scouring on the old disks may happen on the new ones.
How hard can it be?
Nasir
Re: Disc change
« Reply #3 on: December 17, 2012, 07:22:15 pm »
I wouldn't use an old set of pads on new discs, but that's my OCD.
Offline MattR32T
Re: Disc change
« Reply #4 on: December 17, 2012, 08:40:33 pm »
I'd personally changed the pads at the same time aswell
Offline OSB
  • -Given: 32
Re: Disc change
« Reply #5 on: January 11, 2013, 04:50:53 pm »
If there is plenty of meat left on the pads and there is only light scoring you can flat the surface by rubbing them on a sheet of abrasive paper which in turn on a flat surface like piece of glass. You have to be very carful that you don't wear down one side more that another.
Can be done - ive done it several times in my finacially poor youth.
But as has been said - best to fit new pads. Is running into the back of a car worth a few quid .....
Re: Disc change
« Reply #6 on: January 11, 2013, 04:53:40 pm »
Not quite
The calipers are bolted to the carrier. You need to take the caliper off and then remove the carrier.
Offline john a
    • The Veneers Cover Band
Re: Disc change
« Reply #7 on: January 11, 2013, 10:04:57 pm »
For the price of a set of OE spec pads, I'd be chucking the old ones away.
