Author Topic: Clutch change - What should you do at the same time?  (Read 1199 times)
Offline Mk5 GTian
  • -Receive: 37
« on: December 21, 2012, 09:33:57 am »
I read on a thread recently that whilst you are changing your clutch there was something else you should do to save on labour, or it might have been the other way round, i.e. you are changing something and might as well do the clutch as well?  :confused:
Offline jimk04
Re: Clutch change - What should you do at the same time?
« Reply #1 on: December 21, 2012, 09:54:46 am »
Slave cylinder....release bearing.....crankshaft oil seal.....gearbox input shaft seal?!
Milltek tbe, Forge intercooler, AMD map, Eibach Sportlines, Porsche 996 over AMG 330mm homegrown BBK
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #2 on: December 21, 2012, 09:55:29 am »
Limited slip diff... Well I wish I had done!
Diesel Daily Hack.
Offline Mk5 GTian
  • -Receive: 37
« Reply #3 on: December 21, 2012, 10:07:41 am »
Thanks Dom, so I might as well just go Stage 2, not Stage 2 plus, and save the clutch change for later down the road when I can afford a Quaiffe diff, then go 2+? (I have a lot of other mods to do before the diff, and the clutch is fine at the moment)
So build plans should look like this:
http://www.mk5golfgti.co.uk/forum/index.php/topic,49793.msg570673.html#msg570673
« Last Edit: December 21, 2012, 10:12:16 am by Mk5 GTian »
Offline Gazza747
« Reply #4 on: December 21, 2012, 11:14:14 am »
dual mass flywheel (DMF)
2013 Golf mk7 1.4 tsi SE DSG
2011 Golf mk6 2.0 tdi Match manual (sold)
2007 Golf mk5 GTi manual (sold)
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #5 on: December 21, 2012, 11:17:24 am »
lsd, slave cylinder
