Author Topic: Porsche caliper's upgrade on Edition 30  (Read 9283 times)
Offline oak_grun
« on: January 06, 2013, 04:08:49 pm »
Hi, I'm currently looking to upgrade the standard front brakes and have been offered some Brembo Porsche caliper's.
Part No.996.352.421 & 996.352.422
Will they fit?
Offline oak_grun
Re: Porsche caliper's upgrade on Edition 30
« Reply #2 on: January 06, 2013, 04:29:01 pm »
Thanks!
« Reply #3 on: January 06, 2013, 04:53:27 pm »
Those 996 caliper are not the ones from the NQSBKK...  :happy2:
« Last Edit: January 06, 2013, 09:18:59 pm by richwig83 »
Offline oak_grun
« Reply #4 on: January 06, 2013, 07:01:33 pm »
So the correct ones have 351 in the part number?
 Which year and model do the correct caliper's come from out of interest?
Thanks :smiley:
« Last Edit: January 06, 2013, 07:09:52 pm by oak_grun »
« Reply #5 on: January 06, 2013, 07:09:01 pm »
Begin with 986.
Offline oak_grun
« Reply #6 on: January 06, 2013, 08:43:01 pm »
Begin with 986.
What model Porsche do the correct ones from off?
« Reply #7 on: January 06, 2013, 08:45:27 pm »
Errr... Boxster 2.7 i think.
986.351.421
986.351.422
  • -Receive: 427
« Reply #8 on: January 06, 2013, 09:13:39 pm »
IIRC the NQS BBK Calipers are from the Porsche Boxster 2.5 & 2.7.
Taken from DaveB's thread....
The part numbers you need are 986 351 421 & 422
Just a brief explanation of part numbers:
First three are the model number 986=Boxster, 996=911, 955=Cayenne
351 = Front brakes
421 Left Caliper (odd numbers) & 422 Right Caliper (Even numbers)
Dont buy anything with a 352 in the part number they are rear calipers and the pistons are too small for a Mk5
Offline Shorty
  • -Receive: 24
« Reply #9 on: January 06, 2013, 09:21:01 pm »
I run the 996 calipers that you have been offered, run with a 330mm Mercedes disc and they are immense. Really good stopping power!
| Mk7 R |
Offline gobbleplease
  • -Given: 64
  • -Receive: 48
« Reply #10 on: January 06, 2013, 09:26:26 pm »
What sort of size spacers do you need with the 996 calipers and merc set up ?
MK7 GTI - ARRIVING DECEMBER
Offline jimk04
« Reply #11 on: January 06, 2013, 10:18:55 pm »
15mm on 17" monza
Milltek tbe, Forge intercooler, AMD map, Eibach Sportlines, Porsche 996 over AMG 330mm homegrown BBK
Offline bacillus
  • -Receive: 451
« Reply #12 on: January 06, 2013, 10:34:58 pm »
15mm on 17" monza
Is there not a rubbing issue if you use such a thick spacer at the front?
Offline jimk04
« Reply #13 on: January 07, 2013, 07:44:40 pm »
I have -45mm Eibach springs - and drive like a bit of a lunatic when out on my own in the country...and If I catch a bump mid corner when really loaded up - it will catch slightly, but nothing to worry about...ot that you can see the result of on either tyre or arch liner or wing.
Offline Shorty
  • -Receive: 24
« Reply #14 on: January 07, 2013, 08:02:35 pm »
Yeah i run 15mm spacers on my 18" Pescara's. Lowered on KW V1's and only rubs when your proper on it.  :happy2:
| Mk7 R |
