Author Topic: DIY Cam Follower vid finished  (Read 14787 times)
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« on: January 07, 2013, 05:26:32 am »
Here is my cam follower replacement process I do every 10k miles along with every other oil change...because HPFP is upgraded. Mine is Bamboo fitting and doesn't show how to tackle the Banjo bolt. If you do not have an upgraded HPFP by APR, Autotech, I.E., or other...your stock oem cam follower is likely going to get worn through from 80k miles on;
« Last Edit: September 09, 2017, 06:07:12 pm by ROH ECHT »
Offline ianv5
Re: DIY Cam Follower vid finished
« Reply #1 on: January 07, 2013, 05:42:06 am »
Finally got back with the neighbor to finish cutting this piece for the can.
    Here is my cam follower replacement process I do every 10k miles along with every other oil change;
Awesome Video mate, this should be made a Sticky :congrats: :congrats: :congrats:
Will replace mine in a week or so!
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #2 on: January 07, 2013, 06:08:12 am »
It just may be moved soon, yes?
I wanted for a long time to make some diy vids covering things that would help the diy'rs. This is stuff I do every 10k miles so the cost of the follower replacement is $50usd and the cost for lightly cleaning the intake valves for me is the cost of 10 to 12oz of mineral spirits(a good valve cleaner of choice could be sub'd).
« Reply #3 on: January 07, 2013, 08:05:22 am »
Great... i will add these guides to the thread!
« Reply #4 on: January 07, 2013, 08:09:03 am »
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #5 on: January 07, 2013, 08:19:48 am »
No prob. I will always, in the future, make a diy vid when doing something as it is likely to be something we all can do...if I can do it.  :rolleye:
« Reply #6 on: January 07, 2013, 08:26:00 am »
Please do.  :happy2:  Its often daunting to attempt something from a written guide... videos are much better.
When you make the other videos... do the same as you have done, and create a post ( in this thread http://www.mk5golfgti.co.uk/forum/index.php/board,9.0.html ) and i will then add them to the How To Guide Thread at the top.
Offline bacillus
  • -Receive: 453
« Reply #7 on: January 07, 2013, 01:51:54 pm »
Just to add that a bit more effort will be needed if you have a banjo bolt attaching your fuel line to the hpfp. This diy only deals with those cars that have the flexible hose to hpfp which is easier to do.
btw I thought that the safest way to relieve the excess pressure in the rail was to bleed the Schrader valve.
Offline andygo
« Reply #8 on: January 07, 2013, 04:34:54 pm »
How much are followers from VW in the UK?
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
« Reply #9 on: January 07, 2013, 04:58:43 pm »
About £28.
'07 Red manual
Offline S2 Ant
  • -Receive: 21
« Reply #10 on: January 07, 2013, 04:58:44 pm »
Meant to be around £20-£30
Ant
Offline GTI-Ross
  • Learning All The Time :)
« Reply #11 on: January 07, 2013, 10:44:34 pm »
What is a Cam Follower and what does it do.....what improvement do you get from changing?
« Reply #12 on: January 07, 2013, 10:47:28 pm »
Think of the cam follower as a bucket shaped 'bearing' or 'washer' which goes between the fuel pump actuator and the cam lobe. Without the follower the pump actuator would destroy the cam lobes.
« Reply #13 on: January 07, 2013, 10:50:17 pm »
http://www.mk5golfgti.co.uk/forum/index.php/topic,57710.0.html
Offline GTI-Ross
« Reply #14 on: January 07, 2013, 10:55:29 pm »
Holy sh*t...better get it changed then after reading that....i watched the video...is it the same on a 05 plate GTI?  Thanks
