Author Topic: MK5 Golf weight - Low Jack Question  (Read 8626 times)
Offline chrisr763
  • -Receive: 62
Re: MK5 Golf weight - Low Jack Question
« Reply #30 on: January 17, 2013, 11:01:24 am »
I've got this one.
http://www.workshopping.co.uk/product/trolley-jack-15tonne-aluminium-rocket-lift/RJA1500/?utm_source=google&utm_medium=shop&utm_campaign=feed
I realise its a bit more than the ones you've put up. Can't fault the Sealey build quality and the twin piston rocket lift works a treat.
....That looks as if it would cope very well with very low cars (mine has only 95mm road clearance). Do you know if it does?
Capacity:1.5tonne
Minimum Saddle Height:85mm
Maximum Saddle Height:445mm
Maximum Chassis Height:145mm
Length:625mm
Weight:20kg
Offline simonp
  • -Receive: 38
  • No longer a Golfer
« Reply #31 on: January 17, 2013, 11:09:03 am »
Why is the 2.5 tonne version cheaper?
Offline lm_gauci
« Reply #32 on: January 17, 2013, 11:12:17 am »
Model No:RJAS2500
Capacity:2.5tonne
Minimum Saddle Height:94mm
Maximum Saddle Height:468mm
Maximum Chassis Height:150mm
Length:592mm
Weight:26kg
In comparison to the one above. Its partly made of steel so heavier and not as low entry.
  • -Given: 380
  • -Receive: 442
« Reply #33 on: January 17, 2013, 11:15:28 am »
I've just had a phone chat with Workshopping about those lightweight jacks and the saddle height at the jacking point is the critical measurement.
The guy I spoke to was extremely helpful and not at all a hard-sell but more interested in a customer getting what they actually need. He reckoned that a Mk5 Golf would be fine on a 1.5 tonne rated jack especially as the jack wouldn't be lifting up the whole car!
Offline lm_gauci
« Reply #34 on: January 17, 2013, 11:15:59 am »
EDIT: Actually I've just read that its max chassis height is 145mm so I guess it wouldn't work on mine.
Where are you jacking it up from Robin? Off the sill should be fine as it doesnt go that far in to get to the jacking points.
Offline chrisr763
  • -Receive: 62
« Reply #35 on: January 17, 2013, 11:17:58 am »
I was told a 1.25T jack would be fine on a MK5 Golf as again, it isnt lifting the whole car.  :popcornsoda:
  • -Given: 380
  • -Receive: 442
« Reply #36 on: January 17, 2013, 11:20:04 am »
....Always safer to use the jacking points. I would have to venture into my car's batcave with my tape measure to check it [says he who actually doesn't need to buy a jack and can't really afford it anyway].
Offline paulw123
  • -Receive: 47
« Reply #37 on: January 17, 2013, 01:20:22 pm »
got these jacking pads on mine
http://www.psituning.com/product.php/21370/ecs_volkswagen___audi_jack_pad_adapter
better safe than sorry when crawling underneath, then lower onto axel stands under jacking points.
Offline chrisr763
  • -Receive: 62
« Reply #38 on: January 17, 2013, 02:32:33 pm »
Do these
Fit a TDI?
« Reply #39 on: January 17, 2013, 02:50:18 pm »
Jack.
They also had 3 tonne  ratchet axle stands for about 15quid.
Offline bigmig95
  • -Receive: 50
« Reply #40 on: January 17, 2013, 03:11:01 pm »
Got one of these a couple of weeks back....Superb  :happy2:
Offline paulw123
  • -Receive: 47
« Reply #41 on: January 17, 2013, 03:48:31 pm »
Do these
Fit a TDI?
Yes Chris, i think the floorpan design is the same on all golf mk5's, they fit my gt tdi ok.
Offline Mandy
  • -Given: 95
  • -Receive: 94
Offline chrisr763
  • -Receive: 62
« Reply #43 on: January 17, 2013, 03:57:44 pm »
I know nothing about jacks lol, are these any good?
From Lidl £19.99, 3yrs warranty:
http://www.lidl.co.uk/cps/rde/xchg//SID-7FF48947-0BD4AD7B/lidl_uk/hs.xsl/index_35171.htm?offerdate=&ar2=&ERR=noservice
From Halfords, £21.99:
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_217011_langId_-1_categoryId_255207
Both 2 tonne.
Lidl one looks like a toy to me im sorry.  Doesnt get my vote.
Basically the reason this topic was started was because my current jack, similar to the halfords one doesnt fit under my lowered car.
The halfords one will do a standard height GTi or most other cars not 4x4 (truck)  fine  :happy2:
PLease read below
« Last Edit: January 17, 2013, 04:00:27 pm by chrisr763 »
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=iufupo2l1h4nfrrcgrend5i46f&/topic,19740.0.html
« Reply #44 on: January 17, 2013, 03:59:19 pm »
Mandy... those ones really chew the chassis of your car up, avoid.
