Hey Graeme,
Thanks for the info. How do you find running both coolers? I've heard a couple of people now mention that they believe that running the two might cause extra lag due to the extra intake pressure?
I have the S3 and thinking of adding the front mount (forge or airtec) any help / advice much appreciated
james i added the twintercooler to my s3 last august. now pdt, at the time of fitting found a boost leak, so this was probably as much of the improvement but i found 40hp on the dyno and the drive home was
i did lose 10lb ft of torque though after fitting the twintercooler. but you cant notice any lag and 358lb ft to 348lb ft did not notice on the road either.
