Author Topic: Wiring for cruise control?  (Read 3127 times)
Offline A1dan2.0tdisport
Re: Wiring for cruise control?
« Reply #15 on: February 11, 2013, 07:12:49 pm »
You can tell by your vin number
2006MY = WVWZZZ1KZ6W??????
2005MY = WVWZZZ1KZ5W??????
If that's your vin code then you have the wire already installed?
My number plate is MT06. Make much difference Eddie?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #16 on: February 11, 2013, 07:15:27 pm »
If your vin says your car is a 2006 car then it will be ok
don't go by reg as some cars were not registered straight away
Cluster and Key coding
Location Great Yarmouth
Offline torque777
Re: Re: Wiring for cruise control?
« Reply #17 on: February 11, 2013, 07:17:42 pm »
That's interesting I have a tdi in s spec and was told by vw it would be £300  even thou it is a 57 plate with a 08 build ...
sent using my own fingers
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #18 on: February 11, 2013, 07:19:21 pm »
As you have an S spec you need a controller
Where are you located
Offline torque777
« Reply #19 on: February 11, 2013, 07:31:16 pm »
I'm in Shropshire .....dam poverty spec
Offline Coe
« Reply #20 on: February 11, 2013, 09:52:13 pm »
If it helps when you look at the wiring unit under the steering column the wire you need for cruise is a single black and white wire. I have this on good authority  :happy2:
My car is an 05 GTI and it had the wire. Thank f$*k for that. Golfman fitted mine.
Offline MightyMullet
  • Penzance, Cornwall
« Reply #21 on: February 11, 2013, 10:04:11 pm »
Awesome info Eddie, mine is WVWZZZ1KZ6W so itll have the wiring? Thanks forthe help, means alot  :drinking:
« Reply #22 on: February 11, 2013, 10:29:22 pm »
This is my vin. Just to confirm that I will or will not need the wire
WWWZZZ1KZ6B
Thanks for help Eddie mate
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ndb8chah0rfalqb23d3po4fsrq&/topic,19740.0.html
« Reply #23 on: February 11, 2013, 10:45:17 pm »
I wouldnt post your VIN on a public forum.
« Last Edit: February 11, 2013, 10:48:15 pm by richwig83 »
« Reply #24 on: February 11, 2013, 10:47:25 pm »
Thanks rich iv edited mine. Can people get any info from that now?
And could you edit your quote to suit thanks mate,
« Reply #25 on: February 11, 2013, 10:48:45 pm »
Done.... just better safe than sorry.  :happy2:
« Reply #26 on: February 12, 2013, 12:11:36 am »
ye thanks mate appreciate you looking out for forum Members :)
