Author Topic: MPG down by quite a bit. Possible causes?  (Read 2080 times)
Offline Craigh1983
    • Leicester Wedding Photographers
« on: February 19, 2013, 08:59:03 pm »
Hi guys,
My car usually manages around 330mpg most times I fill up with a full tank of petrol. However this month I have only managed 290 mpg and I have driven the car the same, on the same roads so I can't understand why this could be.
Didn't know if there are any possible causes for this?
Also i bought my car a year ago, it has now done 110,000 miles and there are no records of the dv valve being changed? so i wondered if it was worth getting my DV valve changed when I'm next at the garage to the revision G?
Offline GTI-Ross
  • Learning All The Time :)
Re: MPG down by quite a bit. Possible causes?
« Reply #1 on: February 19, 2013, 10:12:44 pm »
Seriously bro, since changing mine to Rev G, seen a 3-4 MPG increase.....not massive but over the year. I used to think i was my lead right foot...turns out torn DV, get it changed mate :happy2:
Offline sub39h
  • -Given: 189
  • -Receive: 84
« Reply #2 on: February 19, 2013, 10:19:19 pm »
330mpg mpg? now 290mpg? if i was getting 290mpg from my 2.0T i would not be complaining!
PLANS: Stage 2+
Offline Craigh1983
« Reply #3 on: February 20, 2013, 08:10:09 am »
Yea will definately do it. Maybe I will see an increase in performance too?
Offline Craigh1983
« Reply #4 on: February 20, 2013, 08:10:45 am »
Lol i'm a bit of a boring driver! :)
Offline Luka
« Reply #5 on: February 20, 2013, 08:28:03 am »
3000 miles to a full tank!
If only...  :signLOL:
Sold - 2006 Tornado Red GTI 3dr
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #6 on: February 20, 2013, 08:34:56 am »
If there are no error codes on vcds it is likely a failing maf sensor. But you can check that logging group 002. Or if you know another with a maf you can ask them to borrow theirs to run a test with it. Plug it into yours logging both maf sensors or just take it for a short drive with each maf resetting the mean mpg on the same stretch of road setting cruise at the same for both maf's. Assuming theirs is good you will see a diff in the avg.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #7 on: February 20, 2013, 11:58:37 am »
Cold weather will hammer your MPG too. Makes a big difference ive found
Offline andyR43
« Reply #8 on: February 20, 2013, 01:33:34 pm »
Check your tyre pressures in this cold weather as, when the temperature drops the pressure in your tyres will drop too. This will result in a corresponding drop in MPG so re-inflating them to the correct pressures will restore some of your missing MPG.  :happy2:
Keeping it original..............or not!!
Offline gazon69
« Reply #9 on: February 20, 2013, 01:45:33 pm »
mine was doing 14mpg driving steady when cam follower went.
Offline Craigh1983
« Reply #10 on: February 20, 2013, 03:01:56 pm »
I did have a new MAF sensor fitted actually when i first bought the car a year ago. I hope it wouldn't be failing this early on?
homesqueeze
« Reply #11 on: February 20, 2013, 06:02:34 pm »
My mpg got noticeably lower when my dv was knackered.
