Author Topic: How easy is it to remove front bumper?  (Read 1154 times)
Offline vaheedakhtar
« on: February 23, 2013, 10:24:49 pm »
Has anyone here ever removed the front bumper before?
I have a brand new bumper, all sprayed and ready to replace the one I smashed by crashing into my own wall last week  :ashamed: - is there any tips to make this task any easier?
I have axle stands and a trolley jack to help me elevate the front of the vehicle; also a collection of torx crews etc. Anything else I might need?
cheers  :drinking:
Offline doylebros
  • -Receive: 310
Re: How easy is it to remove front bumper?
« Reply #1 on: February 23, 2013, 10:26:29 pm »
Offline chrisr763
  • -Receive: 62
« Reply #2 on: February 23, 2013, 10:59:14 pm »
Literally a very easy job. Slightly hardened on a lowered car. But still an easy task. Im assuming its a gti, but makes no difference really.
I would start under the car by removing the torx screws along the front where the splitter joins the car. I count around 8-10. Then remove the centre grill. This should be fairly self explanitory. There are 2 screws at the top & two under the plate surround at either side. This should then foward and off.
The next part is to tackle the torx in the wheel arches. There are 4/5 either side. 3/4 holding the arch liner to the bumper & 1 that is virtical. Then repeat the other side.
Then you should be able to pull from the wheel arch and it will pop off  :happy2:
Offline Trekmeister
  • Golf GT 140
Re: Re: How easy is it to remove front bumper?
« Reply #3 on: February 24, 2013, 05:13:24 pm »
What about headlight alignment, whats the best way to make sure the beams are correct?
Sent from my GT-I9300 using Tapatalk 2
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #4 on: February 24, 2013, 05:31:10 pm »
Get a professional to look at them!
Offline Trekmeister
  • Golf GT 140
« Reply #5 on: February 24, 2013, 08:33:22 pm »
Does that mean they can be adjusted with bumper in place?
Offline dokez
« Reply #6 on: February 24, 2013, 08:40:08 pm »
Yes, adjusters are on top of lights.
